Graylog server is not running
Hi All,
i have a graylog cluster setup,using mongodb replica set and Amazon’s elasticsearch service. when i try to start graylog-server in the master getting the below error.
can someone help please!!
See that bit that says “more info on loglevel debug”? Enable debug mode, then come back with those log entries because with the logs you have so far it’s like shooting at a moving target.
