Graylog Pipelines options missing
I’ve recently deployed graylog on OpenSuSE using RPM packages from this community repo. Problem I’m running into is I need to use “Pipelines” but I do not see any options within Graylog Web GUI for piplines. Under System->Configuration->Message Processors", all I see is “Message Filter Chaing”
What am I missing?
Not sure if it’s relevant, but I am running graylog over SSL.
Thank you for all your help
your installation looks like the default plugins are stripped off - why you did not use the .rpm provided by Graylog?
http://packages.graylog2.org/el/stable/2.4/x86_64
thanks for the reply. I don’t think Graylog offers RPM packages for openSuSE.
installing graylog from official repo did not resolve it Finally it worked when I I specify absolute path to plugins directory in the .conf file.
Thanks for your help
