I’m trying to get started with blacklisting some messages and need to process my rules after some extractions happen, but I just noticed that the pipeline processor isn’t showing up in the System/Configurations/Message Processors Configuration UI. I do see entries for it in the startup log:
2017-09-06 12:07:38,948 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Elastic Beats Input 2.3.1 [org.graylog.plugins.beats.BeatsInputPlugin]
2017-09-06 12:07:38,953 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Collector 2.3.1 [org.graylog.plugins.collector.CollectorPlugin]
2017-09-06 12:07:38,956 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Enterprise Integration Plugin 2.3.1 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2017-09-06 12:07:38,958 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: MapWidgetPlugin 2.3.1 [org.graylog.plugins.map.MapWidgetPlugin]
2017-09-06 12:07:38,979 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Pipeline Processor Plugin 2.3.1 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2017-09-06 12:07:38,981 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Anonymous Usage Statistics 2.3.1 [org.graylog.plugins.usagestatistics.UsageStatsPlugin]
2017-09-06 12:07:39,535 INFO : org.graylog2.bootstrap.CmdLineTool - Running with JVM arguments: -XX:+UnlockExperimentalVMOptions -XX:+UseCGroupMemoryLimitForHeap -XX:NewRatio=1 -XX:MaxMetaspaceSize=256m -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=/usr/share/graylog/data/config/log4j2.xml -Djava.library.path=/usr/share/graylog/lib/sigar/ -Dgraylog2.installation_source=docker
Any idea on how I can debug this issue?
