Configuring Pipeline through API
how can i configure a Pipeline without any Binding or Rule with the API like i can in Webinterface?
-hasturo
please check the API Browser for that or check this ansible modul:
Hi Jan,
in those ansible Modules, the attribute “source” is mandantory. Also in API Browser this Option is mandantory, even if the description says its optional.
-hasturo
the description might be wrong - what is your question?
So is the Description wrong and you cannot create a Pipeline with the API, without defining a Source at the same time or is it a Bug?
If its only a wrong Description i have to adapt my workflow and can go on with my work and the Description should be changed.
he @hasturo
do you mind opening a bug report over at:
thx
