Graylog Not Starting Caused by: java.lang.NumberFormatException: For input string: "XDB3"
My CentOS 8 testing image rebooted last night. This morning, Graylog wasn’t started and refused to start with the following error:
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.bootstrap.Main.main(Main.java:50)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: 31) Error injecting constructor, java.lang.NumberFormatException: For input string: “XDB3”
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.shared.journal.KafkaJournal.(KafkaJournal.java:191)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.shared.journal.KafkaJournal.class(KafkaJournal.java:101)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.shared.journal.KafkaJournal
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.shared.journal.KafkaJournalModule.configure(KafkaJournalModule.java:25) (via modules: org.graylog2.bindings.>
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.shared.journal.Journal
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 2nd parameter of org.graylog2.shared.buffers.JournallingMessageHandler.(JournallingMessageHandler.java:67)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.shared.buffers.JournallingMessageHandler
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.shared.buffers.InputBufferImpl.(InputBufferImpl.java:55)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.shared.buffers.InputBufferImpl.class(InputBufferImpl.java:45)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.shared.buffers.InputBufferImpl
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.plugin.buffers.InputBuffer
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 2nd parameter of org.graylog2.shared.inputs.InputLauncher.(InputLauncher.java:47)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.shared.inputs.InputLauncher
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 3rd parameter of org.graylog2.shared.initializers.InputSetupService.(InputSetupService.java:50)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.shared.initializers.InputSetupService.class(InputSetupService.java:40)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.shared.initializers.InputSetupService
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: Caused by: java.lang.NumberFormatException (same stack trace as error #18)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: 32) Error injecting constructor, java.lang.NumberFormatException: For input string: “XDB3”
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 4th parameter of org.graylog2.outputs.BlockingBatchedESOutput.(BlockingBatchedESOutput.java:76)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.outputs.BlockingBatchedESOutput
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.bindings.MessageOutputBindings.configure(MessageOutputBindings.java:51)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.plugin.outputs.MessageOutput annotated with @org.graylog2.outputs.DefaultMessageOutput()
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 1st parameter of org.graylog2.outputs.OutputRegistry.(OutputRegistry.java:71)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.outputs.OutputRegistry.class(OutputRegistry.java:51)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.outputs.OutputRegistry
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 4th parameter of org.graylog2.streams.OutputServiceImpl.(OutputServiceImpl.java:55)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.streams.OutputServiceImpl
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 4th parameter of org.graylog2.streams.StreamServiceImpl.(StreamServiceImpl.java:97)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.streams.StreamServiceImpl
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 3rd parameter of org.graylog2.indexer.indexset.MongoIndexSetService.(MongoIndexSetService.java:58)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.indexer.indexset.MongoIndexSetService
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.indexer.indexset.IndexSetService
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 1st parameter of org.graylog2.indexer.MongoIndexSetRegistry.(MongoIndexSetRegistry.java:89)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.indexer.MongoIndexSetRegistry.class(MongoIndexSetRegistry.java:89)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.indexer.MongoIndexSetRegistry
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.indexer.IndexSetRegistry
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 4th parameter of org.graylog2.indexer.ranges.MongoIndexRangeService.(MongoIndexRangeService.java:75)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.indexer.ranges.MongoIndexRangeService
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.bindings.PersistenceServicesBindings.configure(PersistenceServicesBindings.java:61)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.indexer.ranges.IndexRangeService
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: for the 2nd parameter of org.graylog2.indexer.searches.Searches.(Searches.java:196)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.indexer.searches.Searches.class(Searches.java:116)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: while locating org.graylog2.indexer.searches.Searches
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: Caused by: java.lang.NumberFormatException: For input string: “XDB3”
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at java.lang.Long.parseLong(Long.java:589)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at java.lang.Long.parseLong(Long.java:631)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.shared.journal.KafkaJournal.(KafkaJournal.java:304)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.shared.journal.KafkaJournal$$FastClassByGuice$$8f50433e.newInstance()
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFacto>
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:148)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:39)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:62)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:42)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:65)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:113)
lines 882-936/1024
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:211)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:182)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.Guice.createInjector(Guice.java:87)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.shared.bindings.GuiceInjectorHolder.createInjector(GuiceInjectorHolder.java:34)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.bootstrap.CmdLineTool.setupInjector(CmdLineTool.java:379)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:194)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: 32 errors
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:543)
Apr 29 08:27:31 mylinbox.thehoff.local graylog-server[28323]: at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:186)
Apr 29 08:27:31 mylinbox.thehoff.local mongod[1669]: {“t”:{“$date”:“2021-04-29T08:27:31.934-07:00”},“s”:“I”, “c”:“NETWORK”, “id”:22944, “ctx”:“conn175”,“msg”:“Connection ended”,“attr”:>
Apr 29 08:27:31 mylinbox.thehoff.local mongod[1669]: {“t”:{“$date”:“2021-04-29T08:27:31.934-07:00”},“s”:“I”, “c”:“NETWORK”, “id”:22944, “ctx”:“conn174”,“msg”:“Connection ended”,“attr”:>
Apr 29 08:27:31 mylinbox.thehoff.local systemd[1]: graylog-server.service: Main process exited, code=exited, status=1/FAILURE
Apr 29 08:27:31 mylinbox.thehoff.local systemd[1]: graylog-server.service: Failed with result ‘exit-code’.
– Subject: Unit failed
– Defined-By: systemd
– Support: https://access.redhat.com/support
– The unit graylog-server.service has entered the ‘failed’ state with result ‘exit-code’.
Apr 29 08:27:38 mylinbox.thehoff.local mongod[1669]: {“t”:{“$date”:“2021-04-29T08:27:38.180-07:00”},“s”:“I”, “c”:“STORAGE”, “id”:22430, “ctx”:“WTCheckpointThread”,“msg”:"WiredTiger mes>
Apr 29 08:27:42 mylinbox.thehoff.local systemd[1]: graylog-server.service: Service RestartSec=10s expired, scheduling restart.
Apr 29 08:27:42 mylinbox.thehoff.local systemd[1]: graylog-server.service: Scheduled restart job, restart counter is at 76.
– Subject: Automatic restarting of a unit has been scheduled
Any ideas?
@skinfrakki
This is very hard to read , could you reformat you post please.
https://community.graylog.org/t/community-guidelines/6649#format-markdown
Thank you
In short, when you are posting code or logs, use the </> tool in your forum toolbar to make code look nice:
What is the status of your Mongo database? I have Ubuntu but it should be similar… - here is my output(using formatting):
$ service mongod status
● mongod.service - MongoDB Database Server
     Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset: enabled)
     Active: active (running) since Tue 2021-04-20 03:05:18 EDT; 1 weeks 3 days ago
       Docs: https://docs.mongodb.org/manual
   Main PID: 675 (mongod)
     Memory: 4.3G
     CGroup: /system.slice/mongod.service
             └─645 /usr/bin/mongod --config /etc/mongod.conf
Apr 20 03:05:18 GL-SRV72 systemd[1]: Started MongoDB Database Server.
