Graylogservice does not start because of java?
we installed the latest graylog, we are not able to get on the webinterface since the service does not start.
OS Information: Debian 10
We configured the server.conf, added the password hashes and so on.
Log:
Caused by: java.lang.RuntimeException: Could not parse URI.
	at org.graylog2.plugin.Tools.getUriWithScheme(Tools.java:546) ~[graylog.jar:?]
	at org.graylog2.plugin.Tools.lambda$normalizeURI$0(Tools.java:598) ~[graylog.jar:?]
	at java.util.Optional.map(Optional.java:265) ~[?:?]
	at org.graylog2.plugin.Tools.normalizeURI(Tools.java:598) ~[graylog.jar:?]
	at org.graylog2.configuration.HttpConfiguration.getHttpPublishUri(HttpConfiguration.java:118) ~[graylog.jar:?]
	at org.graylog2.configuration.HttpConfiguration.validateHttpPublishUriPathEndsWithSlash(HttpConfiguration.java:234) ~[graylog.jar:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
	at com.github.joschi.jadconfig.ReflectionUtils.invokeMethodsWithAnnotation(ReflectionUtils.java:53) ~[graylog.jar:?]
	at com.github.joschi.jadconfig.JadConfig.invokeValidatorMethods(JadConfig.java:221) ~[graylog.jar:?]
	... 4 more
Caused by: java.net.URISyntaxException: Expected scheme-specific part at index 5: http:
	at java.net.URI$Parser.fail(URI.java:2913) ~[?:?]
	at java.net.URI$Parser.failExpecting(URI.java:2919) ~[?:?]
	at java.net.URI$Parser.parse(URI.java:3119) ~[?:?]
	at java.net.URI.<init>(URI.java:685) ~[?:?]
	at org.graylog2.plugin.Tools.getUriWithScheme(Tools.java:544) ~[graylog.jar:?]
	... 4 more
2022-08-11T11:29:55.232+02:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2022-08-11T11:29:55.466+02:00 ERROR [CmdLineTool] Invalid configuration
com.github.joschi.jadconfig.ValidationException: Couldn't run validator method
	at com.github.joschi.jadconfig.JadConfig.invokeValidatorMethods(JadConfig.java:227) ~[graylog.jar:?]
	at com.github.joschi.jadconfig.JadConfig.process(JadConfig.java:100) ~[graylog.jar:?]
	at org.graylog2.bootstrap.CmdLineTool.processConfiguration(CmdLineTool.java:448) [graylog.jar:?]
	at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:256) [graylog.jar:?]
	at org.graylog2.bootstrap.Main.main(Main.java:45) [graylog.jar:?]
Caused by: java.lang.reflect.InvocationTargetException
	... 4 more
	... 4 more
	... 4 more
2022-08-11T11:30:07.450+02:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2022-08-11T11:30:07.868+02:00 ERROR [CmdLineTool] Invalid configuration
	... 4 more
	... 4 more
	... 4 more
Hello @bh-is
Look like a configuration issue. Can you post you Graylog configuration file. If you do please use the markdown so were able to read it correctly, Thanks
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
# ATTENTION: This value must be the same on all Graylog nodes in the cluster.
# Changing this value after installation will render all user sessions and encrypted values in the database invalid. (e.g. encrypted access tokens)
password_secret = zte5yydMw1BSARxK098iG59WFczFBbgc8TG54RW4hnEltUkFxsXZFgafIAQVAQgyJRqGIHj0z3xAcXhRcG9N3Oeegc7SYnWq
#root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = 9a29459f7bcbb75a9f40a59e4d2b4355320f271634680906ef045ebf3d7414d2
# Default is empty
root_email = "test@test.com"
# Default is UTC
#root_timezone = UTC
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
#http_bind_address = 127.0.0.1:9000
http_bind_address = 10.242.2.86:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
http_publish_uri = http://$http_bind_address
#### External Graylog URI
# Default: $http_publish_uri
http_external_uri =http://s9993086:9000
#### Enable CORS headers for HTTP interface
# This allows browsers to make Cross-Origin requests from any origin.
# This is disabled for security reasons and typically only needed if running graylog
# with a separate server for frontend development.
# Default: false
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 16
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
# requires authentication.
# Maximum number of retries to connect to elasticsearch on boot for the version probe.
# Default: 0, retry indefinitely with the given delay until a connection could be established
#elasticsearch_version_probe_attempts = 5
# Waiting time in between connection attempts for elasticsearch_version_probe_attempts
# Default: 5s
#elasticsearch_version_probe_delay = 5s
# Maximum amount of time to wait for successful connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# (e. g. during search, index creation, or index time-range calculations)
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 200
#elasticsearch_max_total_connections = 200
# elasticsearch server).
# Default: 20
#elasticsearch_max_total_connections_per_route = 20
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Set the default scheme when connecting to Elasticsearch discovered nodes
# Default: http (available options: http, https)
#elasticsearch_discovery_default_scheme = http
# Default: false
# Enable use of "Expect: 100-continue" Header for Elasticsearch index requests.
# If this is disabled, Graylog cannot properly handle HTTP 413 Request Entity Too Large errors.
# Default: true
#elasticsearch_use_expect_continue = true
# Graylog will use multiple indices to store documents in. You can configure the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies, the default being "count":
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
#   - "time" interval between index rotations, use elasticsearch_max_time_per_index to configure
# A strategy may be disabled by specifying the optional enabled_index_rotation_strategies list and excluding that strategy.
#enabled_index_rotation_strategies = count,size,time
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see https://docs.graylog.org/docs/index-model#index-set-configuration
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
# Optional upper bound on elasticsearch_max_time_per_index
# elasticsearch_max_write_index_age = 1d
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 1
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: https://docs.graylog.org/docs/query-language
allow_highlighting = false
# Default: 1h
# Default: 20
# Mute the logging-output of ES deprecation warnings during REST calls in the ES RestClient
#elasticsearch_mute_deprecation_warnings = true
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Manually stopped inputs are no longer auto-restarted. To re-enable the previous behavior, set auto_restart_inputs to true.
#auto_restart_inputs = true
# Enable the message journal.
# The directory which will be used to store the message journal. The directory must be exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# '+'-signs in the username or password need to be replaced by '%2B'
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog?replicaSet=rs01
# DNS Seedlist https://docs.mongodb.com/manual/reference/connection-string/#dns-seedlist-connection-format
#mongodb_uri = mongodb+srv://server.example.org/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_subject_prefix = [graylog]
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = false
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of a native system stats collector (currently OSHI)
#disable_native_system_stats_collector = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
# The server is writing processing status information to the database on a regular basis. This setting controls how
# often the data is written to the database.
# Default: 1s (cannot be less than 1s)
#processing_status_persist_interval = 1s
# Configures the threshold for detecting outdated processing status records. Any records that haven't been updated
# in the configured threshold will be ignored.
# Default: 1m (one minute)
#processing_status_update_threshold = 1m
# Configures the journal write rate threshold for selecting processing status records. Any records that have a lower
# one minute rate than the configured value might be ignored. (dependent on number of messages in the journal)
# Default: 1
#processing_status_journal_write_rate_threshold = 1
# Configures the prefix used for graylog event indices
# Default: gl-events
#default_events_index_prefix = gl-events
# Configures the prefix used for graylog system event indices
# Default: gl-system-events
#default_system_events_index_prefix = gl-system-events
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = false
# The directory which contains content packs which should be loaded on the first start of Graylog.
#content_packs_dir = data/contentpacks
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
#content_packs_auto_install = grok-patterns.json
# The allowed TLS protocols for system wide TLS enabled servers. (e.g. message inputs, http interface)
# Setting this to an empty value, leaves it up to system libraries and the used JDK to chose a default.
# Default: TLSv1.2,TLSv1.3  (might be automatically adjusted to protocols supported by the JDK)
#enabled_tls_protocols= TLSv1.2,TLSv1.3
# Enable Prometheus exporter HTTP server.
# Default: false
#prometheus_exporter_enabled = false
# IP address and port for the Prometheus exporter HTTP server.
# Default: 127.0.0.1:9833
#prometheus_exporter_bind_address = 127.0.0.1:9833
# Path to the Prometheus exporter core mapping file. If this option is enabled, the full built-in core mapping is
# replaced with the mappings in this file.
# This file is monitored for changes and updates will be applied at runtime.
# Default: none
#prometheus_exporter_mapping_file_path_core = prometheus-exporter-mapping-core.yml
# Path to the Prometheus exporter custom mapping file. If this option is enabled, the mappings in this file are
# configured in addition to the built-in core mappings. The mappings in this file cannot overwrite any core mappings.
# Default: none
#prometheus_exporter_mapping_file_path_custom = prometheus-exporter-mapping-custom.yml
# Configures the refresh interval for the monitored Prometheus exporter mapping files.
# Default: 60s
#prometheus_exporter_mapping_file_refresh_interval = 60s
# Optional allowed paths for Graylog data files. If provided, certain operations in Graylog will only be permitted
# if the data file(s) are located in the specified paths (for example, with the CSV File lookup adapter).
# All subdirectories of indicated paths are allowed by default. This Provides an additional layer of security,
# and allows administrators to control where in the file system Graylog users can select files from.
#allowed_auxiliary_paths = /etc/graylog/data-files,/etc/custom-allowed-path
psst: you can use the following to view and post only the uncommented lines:
cat /etc/graylog/server/server.conf         | egrep -v "^\s*(#|$)"
Might consider resetting your admin password secret and the root password hash… never a good idea to post that information on a public forum.
When you say you installed the latest version, does that mean you upgraded to that version and this was running or this is a new install and you’ve installed the latest version.
I’m assuming this is a new install and has never been working.
@bh-is
Couple thing I found odd, you could try this suggestion and restart Graylog Service.
You can comment this:
If $http_bind_address contains a wildcard IPv4 address (0.0.0.0), the first non-loopback IPv4 address of this machine will be used.This configuration setting must not contain a wildcard address!
Not sure about you environment, you have a bind IP address already so I believe you can comment this also.
Comment this out.
For troubleshooting, this would be what I would configure with Graylog configuration file.
[root@graylog home]#  cat forum.txt | egrep -v "^\s*(#|$)"
is_master = true
password_secret = password_secert_goes_here
root_password_sha2 = admin password_sha2_goes_here
http_enable_cors = true
http_bind_address = your_ip_address:9000
elasticsearch_shards = 4
ring_size = 65536
Sum it up the error shown below…
I do believe is from these configurations you have, which I suggest to you to comment them.
is_master = true
root_email = "it-administration@bucherhydraulics.com"
ring_size = 65536
actually it is a testing system, but you are totally right. Will do this as soon as it is working properly
2022-08-19T17:36:42.837+02:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2022-08-19T17:36:45.714+02:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 4.2.12 [org.graylog.aws.AWSPlugin]
2022-08-19T17:36:45.716+02:00 INFO  [CmdLineTool] Loaded plugin: Enterprise Integrations 4.2.12 [org.graylog.enterprise.integrations.EnterpriseIntegrationsPlugin]
2022-08-19T17:36:45.719+02:00 INFO  [CmdLineTool] Loaded plugin: Integrations 4.2.12 [org.graylog.integrations.IntegrationsPlugin]
2022-08-19T17:36:45.720+02:00 INFO  [CmdLineTool] Loaded plugin: Collector 4.2.12 [org.graylog.plugins.collector.CollectorPlugin]
2022-08-19T17:36:45.722+02:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise 4.2.12 [org.graylog.plugins.enterprise.EnterprisePlugin]
2022-08-19T17:36:45.723+02:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise (ES6 Support) 4.2.12 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es6.EnterpriseES6Plugin]
2022-08-19T17:36:45.724+02:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise (ES7 Support) 4.2.12 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es7.EnterpriseES7Plugin]
2022-08-19T17:36:45.725+02:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 4.2.12 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-08-19T17:36:45.726+02:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 6 Support 4.2.12+2c655fb [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2022-08-19T17:36:45.726+02:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 4.2.12+2c655fb [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2022-08-19T17:36:45.970+02:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -XX:+$
2022-08-19T17:36:46.321+02:00 INFO  [Version] HV000001: Hibernate Validator null
2022-08-19T17:36:54.881+02:00 INFO  [InputBufferImpl] Message journal is enabled.
2022-08-19T17:36:54.943+02:00 INFO  [NodeId] Node ID: 3fcf6221-b4b5-464d-89c1-cbf0e80e7bed
2022-08-19T17:36:55.493+02:00 INFO  [LogManager] Loading logs.
2022-08-19T17:36:55.572+02:00 WARN  [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000000000000000.index, deleting and rebuilding index...
2022-08-19T17:36:55.670+02:00 INFO  [LogManager] Logs loading complete.
2022-08-19T17:36:55.676+02:00 INFO  [LocalKafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2022-08-19T17:36:55.791+02:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-08-19T17:36:55.881+02:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-08-19T17:36:55.894+02:00 INFO  [cluster] Exception in monitor thread while connecting to server localhost:27017
com.mongodb.MongoSocketOpenException: Exception opening socket
        at com.mongodb.internal.connection.SocketStream.open(SocketStream.java:70) ~[graylog.jar:?]
        at com.mongodb.internal.connection.InternalStreamConnection.open(InternalStreamConnection.java:128) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonitor.java:117) [graylog.jar:?]
        at java.lang.Thread.run(Thread.java:829) [?:?]
Caused by: java.net.ConnectException: Connection refused (Connection refused)
        at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
        at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:412) ~[?:?]
        at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:255) ~[?:?]
        at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:237) ~[?:?]
        at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
        at java.net.Socket.connect(Socket.java:609) ~[?:?]
        at com.mongodb.internal.connection.SocketStreamHelper.initialize(SocketStreamHelper.java:64) ~[graylog.jar:?]
        at com.mongodb.internal.connection.SocketStream.initializeSocket(SocketStream.java:79) ~[graylog.jar:?]
        at com.mongodb.internal.connection.SocketStream.open(SocketStream.java:65) ~[graylog.jar:?]
        ... 3 more
2022-08-19T17:37:25.883+02:00 ERROR [MongoConnectionProvider] Error connecting to MongoDB: Timed out after 30000 ms while waiting to connect. Client view of cluster state is {type=UNKNOWN, servers=[{address=localhost:27017, type=U$
2022-08-19T17:37:25.934+02:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-08-19T17:37:56.111+02:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-08-19T17:38:26.112+02:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-08-19T17:38:56.155+02:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-08-19T17:39:26.406+02:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-08-19T17:39:56.415+02:00 INFO  [InputBufferImpl] Message journal is enabled.
2022-08-19T17:39:56.417+02:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
@gsmith suggested you comment out a few things…
@cawfehman suggested you obfuscate a few things when you post (maybe you can edit your old posts?)…
From what you just posted, it looks like the MongoDB is down… here is what mine looks like up and running…
$ sudo systemctl status mongod
● mongod.service - MongoDB Database Server
     Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset: enabled)
     Active: active (running) since Fri 2022-07-29 14:54:49 EDT; 3 weeks 0 days ago
       Docs: https://docs.mongodb.org/manual
   Main PID: 641 (mongod)
     Memory: 3.8G
     CGroup: /system.slice/mongod.service
             └─641 /usr/bin/mongod --config /etc/mongod.conf
Jul 29 14:54:49 cmg-gl01 systemd[1]: Started MongoDB Database Server.
i will give it at try
