Graylog doesn't listen sidecar collector port
My question seems similiar to Port 5044 is closed, cant get it open sidecar-collector windows
Graylog: 3.1
Filebeat 6.8.2
Sidecar: 1.0.1
I have Filebeat configured on a host, it’s in Running state according to Graylog Overview.
Collector configuration:
# Needed for Graylog
fields_under_root: true
filebeat.inputs:
- input_type: log
  paths:
    - /home/app/tomcat/logs/localhost_access_log.*.txt
  type: log
output.logstash:
   hosts: ["10.11.12.13:5045"]
path:
  data: /var/lib/graylog-sidecar/collectors/filebeat/data
  logs: /var/lib/graylog-sidecar/collectors/filebeat/log
Even sidecar is in Running state I don’t see any message from it.
I believe the root cause of it that port 5045 is not listened and I don’t see any related errors in graylog.log
Sidecar log from host confirms it:
2019-09-03T14:59:11.754+0300    ERROR   pipeline/output.go:100  Failed to connect to backoff(async(tcp://10.11.12.13:5045)): dial tcp 10.11.12.13:5045: connect: connection refused
2019-09-03T14:59:11.754+0300    INFO    pipeline/output.go:93   Attempting to reconnect to backoff(async(tcp://10.11.12.13:5045)) with 65 reconnect attempt(s)
I’m sure it can’t be caused by port conflict, but anyway I also tried another ports.
Please advise what can be the reason and what are possible options to debug it.
did you create a beats input in your Graylog?
Follow System > inputs and create a beats input.
OMG, I really forgot this part, thanks a lot, @jan
