hasturo
(Hasturo)
May 11, 2022, 9:57am
1
Hi Guy’s,
im using Graylog 4.0.15+a7bed0d with Docker. Im trying to figure out how i can modify the Startup Logging Level of Graylog. I can set it within the Webgui, but every Time i restart a Container, the setting is back to the default, which is in my case “Info”.
Best regards, hasturo
gsmith
(GSmith)
May 11, 2022, 10:20pm
2
Hello @hasturo
Past couple months I just started using Docker /w docker-compose. I have found it pretty kool to work with.
I might be able to help since the past week or two I was trying to get log/s from the Graylog container.
What I did was the following to reconfigure my log level.
In the Web UI.
Then tail it…
docker logs -f <container_id>
EDIT:
I over looked this, I just tried it out and I have the same problem.
You can set it in this file.
check file /etc/graylog/server/log4j2.xml
https://docs.graylog.org/docs/manual-setup#supplying-external-logging-configuration
<Loggers>
<!-- RestAccessLogFilter -->
<Logger name="org.graylog2.rest.accesslog" level="debug" additivity="false">
<AppenderRef ref="RestAccessLog" level="debug"/>
<AppenderRef ref="AUDITLOG" level="info"/>
</Logger>
<!-- Application Loggers -->
<Logger name="org.graylog2" level="info"/>
<Logger name="com.github.joschi.jadconfig" level="warn"/>
<!-- Prevent DEBUG message about Lucene Expressions not found. -->
<Logger name="org.elasticsearch.script" level="warn"/>
<!-- Disable messages from the version check -->
<Logger name="org.graylog2.periodical.VersionCheckThread" level="off"/>
<!-- Silence chatty natty -->
<Logger name="com.joestelmach.natty.Parser" level="warn"/>
<!-- Silence Kafka log chatter -->
<Logger name="org.graylog.shaded.kafka09.log.Log" level="warn"/>
<Logger name="org.graylog.shaded.kafka09.log.OffsetIndex" level="warn"/>
<Logger name="org.apache.kafka.clients.consumer.ConsumerConfig" level="warn"/>
<!-- Silence useless session validation messages -->
<Logger name="org.apache.shiro.session.mgt.AbstractValidatingSessionManager" level="warn"/>
<Root level="warn">
<AppenderRef ref="rolling-file"/>
<AppenderRef ref="graylog-internal-logs"/>
</Root>
</Loggers>
</Configuration>
Hope that helps
gsmith
(GSmith)
May 11, 2022, 10:57pm
3
To adjust mine, I execute this and reconfigured it manually.
