How can I change the logging level for the Graylog Service or run it in debug mode.
I’m having issues with it starting and would like to run it in Debug mode.
So, I can figure out what is the root cause of the issue.
Thanks,
Thanks,
Go to web interface System - Logging and change log level from info to debug, in desired sections:
If you can’t access web interface, check file /etc/graylog/server/log4j2.xml
Hello Shoothub,
Thank you, that did the trick. Keeping this in my Graylog notes for sure.
Take Care,
