ERROR StatusConsoleListener Deprecated log4j.xml setting detected <bufferSize="500"> Using default <bufferSizeBytes=50MB> instead
I have an issue when I try to install Graylog with docker compose. I have try this link for this compose:
When I run compose up, I got the error message is
ERROR StatusConsoleListener Deprecated log4j.xml setting detected <bufferSize=“500”> Using default <bufferSizeBytes=50MB> instead
What is wrong and how can I fixing it? Any idea please let me know.
Thank in advance.
Hey @qzvt
I’m taking a guess from this error. You Log4j has a Deprecated setting. Might want to take a look in you Log4j configuration file.
I think there is a fix from here.
https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=276098#c0
in the package in log4j2.xml.sample and the log4j2.xml, use the line
Memory name=“graylog-internal-logs” bufferSizeBytes=“50MB”/>
instead of
Memory name=“graylog-internal-logs” bufferSize=“500”/>
starting the service with the wrong option (with the delivered sample config) results in “ERROR StatusConsoleListener Deprecated log4j.xml setting detected <bufferSize=“500”> Using default <bufferSizeBytes=50MB> instead”
