GrayLog and Azure Managed Grafana.
Hello all,
Could I ask for some guidance on integrating Graylog with Azure Managed Grafana? Since Graylog isn’t natively supported, I’m considering using the Elasticsearch instance that Graylog relies on. This way, I could query the logs and create visualizations in Grafana based on Elasticsearch.
Do you think this would be doable?
Can you clarify what your goals or objectives are? Are you trying to use Grafana to query data that graylog has ingested? OR are you trying to use Grafana to view metrics exported from graylog (e.g. prometheus metrics)?
