It is possible to show on grafana all the data from Graylog 3 ?
And how to do it ?
Thank you,
And how to do it ?
Thank you,
Yes, it’s possible. Just use telegraf influxdb to solve it.
how to do this , as I install grafana in another computer , and graylog in the other PC ,
Thank you ,
try to find out and come up here to ask the problem
I upload this dashboard graylog json to grafana
but he said no data found in influxdb
thank you
Install Telegarf, InfluxDB
Try setup it manually and you’ll notice the problem
I finish to install telegraph and influx DB but I don’t know how to configure telegraf/graylog.conf ?
how to know the username and password as a token ?
thank you
Reading docs and create one.
Then you must copy x and paste for username token
And how about password token ?
thank you
password default: tokens
just to be clear: you need telegraf and api tokens to collect graylog metrics (like those available after clicking metrics by the node name on nodes list) in influxdb and display them in grafana, you don’t need those if you want to display data collected by graylog (logs) in elasticsearch, then you just connect grafana to ES data source and that’s it, then you can visualize data on the graphs like you do in graylog dashboards or kibana
Maybe a better question is what are you trying to show on Grafana ?
If you are trying to show the log data, and not the server statistics (which is what Telegraf + InfluxDB would be used for) - then you literally just add the Graylog server as an input like @maniel said. Grafana supports elasticsearch right out of the box.
In fact, that’s exactly how I distribute my reports to the higher-ups. To go a step further, I added an organization in Grafana that allows anonymous RO access and I share a ‘last 30 days’ dashboard in Kiosk mode - with a cron job that sends an HTML-formatted fancy email. Most people think I’ve spent >$100K on an analytics platform.
Just add something like &refresh=5s&from=now-30d&to=now&theme=light&kiosk=tv onto your grafana url to:
Maybe I should do another blog post on this one.
You can check the grafana docs for more.
From your screenshots it looks like you’ve got the input working AFAIK. If it saves and tests OK now you’re on to the grafana forums to figure out what you need on that tool.
the problem is that I don’t receive any log after I connect to elasticsearch.
Grafana and Graylog are in different Host , what should I do ? to show the log from elasticsearch to Grafana
Thank you,
InfluxDB and Telegraf, where is it ??
If you want Elasticsearch source, please check port 9000 or 9200 ??
It is installed on server , that graylog is installed
thanks
Please describe to me, please be clear, I still don’t understand what data you want to post on grafana
Then telegraf and graylog is , in the same host
But the grafana is in another host
thank you
