Hay All
I am trying to secure my connection between Graylog and rabbitMQ
My RabbitMQ config
{rabbit, [
{tcp_listeners, [{"127.0.0.1", 5672}]},
{ssl_listeners, [5671]},
{ssl_options, [{cacertfile,"ca.crt"},
{certfile,"server.crt"},
{keyfile,"server.key"},
{verify,verify_peer},
{fail_if_no_peer_cert,true}
{log, [
{syslog, [{enabled, true},
{level, info},
{identity, "rabbitmq"},
{facility, daemon}
if i set “fail_if_no_peer_cert” to true, Graylog keeps failing to connect to rabbitMQ and i see in the rabbitMQ logs
i see “SSL: certify: ssl_connection.erl:400:Fatal error: handshake failure”
if i set “fail_if_no_peer_cert” to false it works fine
I have Read i need to add the certs to the keystore, but i done this and still no luck.
any help i be gratefull
