I have a RabbitMQ-Server that only allows verified TLS-Connections (v1.1 and v1.2).
When I create a “RAW-AMQP” Input, I am able to check the TLS-Option but launching the Input fails.
In the graylog-logfile I can see a SocketException with the Message “Connection reset”.
On my RabbitMQ-Server I get the error “handshake failure”.
My Question is, which keyfile does graylog use for the handshake? I have nothing configured on the graylog-side yet.
did you use self-signed certificates? If yes Graylog need to be able to verify the certificate and you need to add the Information (CA) to your Keystore.
If not you need to elaborate a little more and maybe post some log files.
thanks for your reply.
yes the certificate is self signed.
When I pull log-messages from the rabbitMQ-Server to the graylog.
Do I have to add the graylog-certificate to the truststore of the rabbitmq server?
Or do I have to add the rabbitmq-certificate to the truststore of the graylog-server?
