Graylog TLS Input
I try to establish a connection to a TLS input and get this error:
io.netty.handler.codec.DecoderException: io.netty.handler.ssl.ReferenceCountedOpenSslEngine$OpenSslHandshakeException: error:100000c0:SSL routines:OPENSSL_internal:PEER_DID_NOT_RETURN_A_CERTIFICATE
  • OS Information:
    Debian 11
  • Package Version:
    graylog-server 5.1.8
I have a wildcard ssl certificate, which i put under trustedClient on the server and also included in the winlogbeat configuration.
Maybe someone had the same issue and knows how to resolve this.
Thank you in advance
Hey @paul199513
Can you show your config for TCP /TLS? By chance are you using Graylog-sidecar or is this just winlogbeat? If so can you show your config for winlogbeat?
