We’ve currently got numerous Windows servers feeding into Graylog via sidecar-configured winlogbeat, the log entries are showing up properly which should mean that connections are being made correctly, but the graylog server logs are rapidly filled with SSL errors. Could somebody help point me as to where the issue might be that is causing all the errors?
Example error messages:
ERROR [AbstractTcpTransport] Error in Input [Beats/5f11ccb5220a9c0a5a0e6a2b] (channel [id: 0xae17782b, L:/<Graylog Server>:5044 ! R:/<Windows Server X>:49280]) (cause io.netty.handler.codec.DecoderException: javax.net.ssl.SSLHandshakeException: error:100000f7:SSL routines:OPENSSL_internal:WRONG_VERSION_NUMBER)
ERROR [AbstractTcpTransport] Error in Input [Beats/5f11ccb5220a9c0a5a0e6a2b] (channel [id: 0x2dbc2e1c, L:/<Graylog Server>:5044 ! R:/<Windows Server Y>:54994]) (cause io.netty.handler.codec.DecoderException: io.netty.handler.ssl.NotSslRecordException: not an SSL/TLS record: 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)
Sidecar configuration:
# Needed for Graylog
fields_under_root: true
output.logstash:
ssl:
enabled: true
verification_mode: none
hosts:
- graylog1.example.com:5044
- graylog2.example.com:5044
- graylog3.example.com:5044
path:
tags:
- windows
winlogbeat:
event_logs:
- name: Application
ignore_older: 72h
- name: System
ignore_older: 72h
- name: Security
ignore_older: 72h
- name: Microsoft-Windows-Sysmon/Operational
ignore_older: 72h
Beats input configuration:
bind_address: 0.0.0.0
no_beats_prefix: false
number_worker_threads: 8
override_source: <empty>
port: 5044
recv_buffer_size: 1048576
tcp_keepalive: false
tls_cert_file: /etc/ssl/certs/cert_file.crt
tls_client_auth: disabled
tls_client_auth_cert_file: <empty>
tls_enable: true
tls_key_file: /etc/ssl/private/key_file.key
tls_key_password: ********
