Graylog beats input TLS enable Error
Hi All,
I am successfully enabled SSL in graylog and application is up and running fine without any issues now I am trying to secure the communication between the Collector and Graylog by enabling the TLS in beats input
As per the documentation, Graylog itself created a new self signed certificate for the input and in the sidecar beats output configuration I marked Enable TLS support & Insecure TLS connection.
After enabling all these changes I am getting the below error in logs,
2017-11-07T04:51:23.854Z INFO  [InputStateListener] Input [Beats/59b794f268521b07e6b29b5f] is now STOPPING
2017-11-07T04:51:23.856Z INFO  [InputStateListener] Input [Beats/59b794f268521b07e6b29b5f] is now STOPPED
2017-11-07T04:51:23.857Z INFO  [InputStateListener] Input [Beats/59b794f268521b07e6b29b5f] is now TERMINATED
2017-11-07T04:51:23.857Z WARN  [AbstractTcpTransport] TLS key file or certificate file does not exist, creating a self-signed certificate for input [Beats/59b794f268521b07e6b29b5f].
2017-11-07T04:51:23.858Z INFO  [InputStateListener] Input [Beats/59b794f268521b07e6b29b5f] is now STARTING
2017-11-07T04:51:23.948Z INFO  [AbstractTcpTransport] Enabled TLS for input [Beats/59b794f268521b07e6b29b5f]. key-file="/tmp/keyutil_0.0.0.0:null_7936124129426110818.key" cert-file="/tmp/keyutil_0.0.0.0:null_6568254468981381412.crt"
2017-11-07T04:51:23.951Z WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input BeatsInput{title=Beats, type=org.graylog.plugins.beats.BeatsInput, nodeId=null} should be 1048576 but is 212992.
2017-11-07T04:51:23.952Z INFO  [InputStateListener] Input [Beats/59b794f268521b07e6b29b5f] is now RUNNING
2017-11-07T04:51:25.863Z ERROR [AbstractRotationStrategy] Cannot perform rotation at this moment.
2017-11-07T04:51:25.869Z ERROR [AbstractRotationStrategy] Cannot perform rotation at this moment.
2017-11-07T04:51:32.738Z WARN  [AbstractTcpTransport] client auth configured, but no authorized certificates / certificate authorities configured
2017-11-07T04:51:32.740Z ERROR [NettyTransport] Error in Input [Beats/873de4f268521b07e6b29b5f] (channel [id: 0xbda8b30d, /xx.xxx.xxx.xx:1072 => /xx.x.x.x:5044])
org.jboss.netty.handler.ssl.NotSslRecordException: not an SSL/TLS record: 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
        at org.jboss.netty.handler.ssl.SslHandler.decode(SslHandler.java:857) ~[graylog.jar:?]
        at org.jboss.netty.handler.codec.frame.FrameDecoder.callDecode(FrameDecoder.java:425) ~[graylog.jar:?]
        at org.jboss.netty.handler.codec.frame.FrameDecoder.messageReceived(FrameDecoder.java:303) ~[graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) ~[graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [graylog.jar:?]
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [graylog.jar:?]
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [graylog.jar:?]
        at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [graylog.jar:?]
        at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [graylog.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_144]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_144]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_144]
Please kindly advice If I am doing anything wrong in the setup.
Should I use the graylog-certificate.pem & graylog-key.pem files generated in using HTTPS ???
Thanks,
Ganeshbabu R
Please post the complete configuration of the Beats input in Graylog, the complete configuration of the Graylog Collector Sidecar, and the configuration file for Filebeat which has generated by the Collector Sidecar.
@jochen
Please find the below informations,
Beats input in Gralog
bind_address: 0.0.0.0
override_source: <empty>
port: 5044
recv_buffer_size: 1048576
tcp_keepalive: false
tls_cert_file: <empty>
tls_client_auth: optional
tls_client_auth_cert_file: <empty>
tls_enable: true
tls_key_file: <empty>
tls_key_password: ********
Configuration of Graylog collector sidecar
server_url: https://graylogserver.southeastasia.cloudapp.azure.com/api/
update_interval: 10
tls_skip_verify: true
send_status: true
list_log_files:
node_id: graylog-collector-sidecar
collector_id: file:/etc/graylog/collector-sidecar/collector-id
cache_path: /var/cache/graylog/collector-sidecar
log_path: /var/log/graylog/collector-sidecar
log_rotation_time: 86400
log_max_age: 604800
tags:
    - linux
    - apache
    - graylogserver
backends:
    - name: nxlog
      enabled: false
      binary_path: /usr/bin/nxlog
      configuration_path: /etc/graylog/collector-sidecar/generated/nxlog.conf
    - name: filebeat
      enabled: true
      binary_path: /usr/bin/filebeat
      configuration_path: /etc/graylog/collector-sidecar/generated/filebeat.yml
Filebeat file
filebeat:
  prospectors:
  - document_type: log
    encoding: plain
    exclude_lines:
    - Ticket
    fields:
      data: example.org
      gl2_source_collector: f4749ffd-1f9b-4ef1-b065-a8fc32388fa1
    ignore_older: 0
    input_type: log
    paths:
    - /etc/graylog/graylogserver*.csv
    scan_frequency: 10s
    tail_files: false
output:
  logstash:
    hosts:
    - graylogserver.southeastasia.cloudapp.azure.com:5044
path:
  data: /var/cache/graylog/collector-sidecar/filebeat/data
  logs: /var/log/graylog/collector-sidecar
tags:
- linux
- apache
- graylogserver
The “logstash” output in Filebeat is missing all SSL/TLS settings.
Hi @jochen
As you mentioned that logstash output in filebeat don’t have SSL settings. I reconfigured the filebeats output in graylog,
and I given the cert & key file paths and saved it. The SSL changes were reflected in the filebeat.yml file,
output:
  logstash:
    hosts:
    loadbalance: false
    ssl:
      certificate: /etc/ssl/nginx_crt.crt
      key: /etc/ssl/nginx_key.key
      verification_mode: none
To use SSL I was trying to configure the beats input with TLS enable and below is the changes made in graylog but I am getting the below error in logs after saving it,
2017-11-07T11:34:49.392Z WARN  [AbstractTcpTransport] client auth configured, but no authorized certificates / certificate authorities configured
2017-11-07T11:34:49.396Z ERROR [NettyTransport] Error in Input [Beats/59b794f268521b07e6b29b5f] (channel [id: 0xd64d29c2, /xx.xxx.xx.xx:1148 => /xx.x.x.x:5044])
org.jboss.netty.handler.ssl.NotSslRecordException: not an SSL/TLS record: 3257000000013243000000b6785e6c8eb14a04311086e3abfcf5dc92648b83a94eae13acb4926be62e036e91e4b88cb2b2e4a97d015951dcc276f8e6fbfef8e09cbb73ce7d2e3864354962025e601f57054367bd9c550c84b38a6173e984834d599b49be82117dd8ef42d8f9fd731adde3573a9394b4960bcd66645b282d02cd5b7b5f5f478bc6f4ded743b1510749eec5893827da79f3dcbdf23e39707e15d6f6daa058c7118070fc2b77cc3f4fe150000ffffe19a4dd6
2017-11-07T11:34:51.899Z WARN  [AbstractTcpTransport] client auth configured, but no authorized certificates / certificate authorities configured
2017-11-07T11:34:51.909Z ERROR [NettyTransport] Error in Input [Beats/59b794f26807e6b29b5f] (channel [id: 0x4d5f787f, /xx.xx.xx.xxx:51084 => /xx.x.x.x:5044])
**javax.net.ssl.SSLHandshakeException: General SSLEngine problem**
        at sun.security.ssl.Handshaker.checkThrown(Handshaker.java:1478) ~[?:1.8.0_144]
        at sun.security.ssl.SSLEngineImpl.checkTaskThrown(SSLEngineImpl.java:535) ~[?:1.8.0_144]
        at sun.security.ssl.SSLEngineImpl.readNetRecord(SSLEngineImpl.java:813) ~[?:1.8.0_144]
        at sun.security.ssl.SSLEngineImpl.unwrap(SSLEngineImpl.java:781) ~[?:1.8.0_144]
        at javax.net.ssl.SSLEngine.unwrap(SSLEngine.java:624) ~[?:1.8.0_144]
        at org.jboss.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:1219) ~[graylog.jar:?]
        at org.jboss.netty.handler.ssl.SslHandler.decode(SslHandler.java:852) ~[graylog.jar:?]
        at org.jboss.netty.handler.codec.frame.FrameDecoder.messageReceived(FrameDecoder.java:310) ~[graylog.jar:?]
Caused by: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
        at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_144]
        at sun.security.ssl.SSLEngineImpl.fatal(SSLEngineImpl.java:1728) ~[?:1.8.0_144]
        at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:304) ~[?:1.8.0_144]
        at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296) ~[?:1.8.0_144]
        at sun.security.ssl.ServerHandshaker.clientCertificate(ServerHandshaker.java:1906) ~[?:1.8.0_144]
        at sun.security.ssl.ServerHandshaker.processMessage(ServerHandshaker.java:233) ~[?:1.8.0_144]
        at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1026) ~[?:1.8.0_144]
        at sun.security.ssl.Handshaker$1.run(Handshaker.java:966) ~[?:1.8.0_144]
        at sun.security.ssl.Handshaker$1.run(Handshaker.java:963) ~[?:1.8.0_144]
        at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_144]
        at sun.security.ssl.Handshaker$DelegatedTask.run(Handshaker.java:1416) ~[?:1.8.0_144]
        at org.jboss.netty.handler.ssl.SslHandler.runDelegatedTasks(SslHandler.java:1393) ~[graylog.jar:?]
        at org.jboss.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:1256) ~[graylog.jar:?]
        ... 19 more
Caused by: java.security.cert.CertificateException: No X509TrustManager implementation available
        at sun.security.ssl.DummyX509TrustManager.checkClientTrusted(SSLContextImpl.java:1191) ~[?:1.8.0_144]
        at sun.security.ssl.ServerHandshaker.clientCertificate(ServerHandshaker.java:1893) ~[?:1.8.0_144]
        ... 19 more
Please correct me If I am doing anything wrong in the setup
Thanks,
Ganeshbabu R
@jochen
Kindly advice if I am doing anything wrong in the above SSL setup of beats input.
I couldn’t able to fix the problem
Thanks,
Ganeshbabu R
Hi, i’m not sure, but it seems that certificate for beats input is not correct, as your logs said:
“java.security.cert.CertificateException: No X509TrustManager implementation available”
Have you removed the passphrase from certificate key?
Is your crt in pem encoded format ?
hope this helps.
Hi @zionio
I generated the cert & key files using the below command,
sudo openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout /etc/ssl/nginx_key.key -out /etc/ssl/nginx_crt.crt
I haven’t given any passphrase while generated key
No its not in pem format
I just followed this documentation
Thanks,
Ganeshbabu R
Hi @jochen
Due to wrong configuration in the beats inputs I was getting the above error and I given the correct path of the cert & key files.
the filebeat are started harvesting the files and below is the details from the /var/log/collector-sidecar/filebeat
2017-11-13T13:57:11Z INFO Starting Registrar
2017-11-13T13:57:11Z INFO Start sending events to output
2017-11-13T13:57:11Z INFO Starting spooler: spool_size: 2048; idle_timeout: 5s
2017-11-13T13:57:11Z INFO Harvester started for file: /etc/graylog/data74.csv
2017-11-13T13:57:11Z INFO Harvester started for file: /etc/graylog/data71.csv
2017-11-13T13:57:11Z INFO Harvester started for file: /etc/graylog/data72.csv
2017-11-13T13:57:11Z INFO Harvester started for file: /etc/graylog/data73.csv
2017-11-13T13:57:41Z INFO Non-zero metrics in the last 30s: filebeat.harvester.open_files=4 filebeat.harvester.running=4 filebeat.harvester.started=4 libbeat.publisher.published_events=1130
2017-11-13T13:57:41Z ERR Connecting error publishing events (retrying): dial tcp 52.187.191.6:5044: i/o timeout
not sure whether this issue is anything related to firewall or port open…
below is the response of netstat -tuplen
It would be very helpful if you could share your thoughts.
Below is the link which helps to setup SSL in beats input and logstash output.
