Graylog 4.3 Problem installing
Installing Graylog on CentOS7 and get error when
sudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-4.2-repository_latest.rpm
file/folder doesn't exist multiple time
**2. Describe your environment:**
* OS Information: Centos 7
* Package Version:
* Service logs, configurations, and environment variables:
**3. What steps have you already taken to try and solve the problem?**
First got certificate error then
Tried --insecure
**4. How can the community help?**
Can't get past above and also when I tried
yum install graylog-server   it stated no package available
**Helpful Posting Tips:**  https://community.graylog.org/t/tips-for-posting-questions-that-get-answers/21828  [Hold down CTRL and link on link to open tips documents in a separate tab]
It looks like they took “repo” out of the path. (@dscryber can help fix that in docs for now )
You can find all the packages here: Graylog Packages. Note that the most recent version of Graylog is 4.3 - probably best to grab that for new installs unless you have a reason for older versions.
Will do. Thanks @tmacgbay
Hello @twtepper
Just chiming in.
I’m kind of confuse, the title says Graylog 4.3 but the package is for 4.2. I see the docs are incorrect.
I have just installed Graylog 4.3 on CentOS 7 and Docker perhaps this will help.
  831  systemctl stop graylog-server
  832  sudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-4.3-repository_latest.rpm
  833  ls
  834  yum clean all
  835  yum update
  836  systemctl start graylog-server
  837  tail -f /var/log/graylog-server/server.log
I am using the open version and I updated like you did and graylog would not start
I noticed some references to enterprise stuff when I issued
service graylog-server status
So i did this
yum remove graylog-enterprise-plugins
and it worked again
HTH
