Graylog 2.4.6 to 2.5.1
Dear All,
I have several Graylog 2.4.6 installs with Elasticsearch 5.6 branch. I have the Elasticsearch data in a separate disk partition.
I can upgrade Graylog to 2.5 using the published method but what i will also need to upgrade the Elasticsearch to 6.x branch for 2.5.1.
Is there any published information on migrating existing data within Elasticsearch 5 to 6 for Graylog as a part of the upgrade from 2.4.6 to 2.5.1?
Cheers
Jake
No need to make the upgrade from ES 5 to ES6 in the same maintenance window. 2.5.x is supporting ES5 and ES6. Just do this one after another. First Graylog after that the Elasticsearch update.
Please read the Release Notes of 2.5 ( https://www.graylog.org/post/announcing-graylog-v2-5 ) - we still miss the guide as some issues keep us busy not writing this guide - but if the check command did not return any indices, just read the ES upgrade notes and follow their upgrade guide.
Cheers Jan
Thanks for the information.
Jake
