Fails to read cloudtrail logs
Fails to read logs from s3
2018-08-01T13:03:35.983Z ERROR [CloudTrailSubscriber] Could not read CloudTrail log file for <app-aws-logs>. Skipping.
com.fasterxml.jackson.databind.JsonMappingException: Unexpected end-of-input in field name
 at [Source: java.io.StringReader@217c2569; line: 1, column: 10026237]
 at [Source: java.io.StringReader@217c2569; line: 1, column: 9999992] (through reference chain: org.graylog.aws.inputs.cloudtrail.json.CloudTrailRecordList["Records"]->java.util.ArrayList[4748])
        at com.fasterxml.jackson.databind.JsonMappingException.wrapWithPath(JsonMappingException.java:388) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.JsonMappingException.wrapWithPath(JsonMappingException.java:360) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:308) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:259) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:26) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.SettableBeanProperty.deserialize(SettableBeanProperty.java:504) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.impl.FieldProperty.deserializeAndSet(FieldProperty.java:111) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BeanDeserializer.vanillaDeserialize(BeanDeserializer.java:276) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BeanDeserializer.deserialize(BeanDeserializer.java:140) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:3814) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:2858) ~[graylog.jar:?]
        at org.graylog.aws.inputs.cloudtrail.messages.TreeReader.read(TreeReader.java:19) ~[graylog-plugin-aws-2.4.6.jar:?]
        at org.graylog.aws.inputs.cloudtrail.CloudTrailSubscriber.run(CloudTrailSubscriber.java:108) [graylog-plugin-aws-2.4.6.jar:?]
Caused by: com.fasterxml.jackson.core.io.JsonEOFException: Unexpected end-of-input in field name
        at com.fasterxml.jackson.core.base.ParserMinimalBase._reportInvalidEOF(ParserMinimalBase.java:483) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._parseName2(ReaderBasedJsonParser.java:1716) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._parseName(ReaderBasedJsonParser.java:1700) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextFieldName(ReaderBasedJsonParser.java:921) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.BeanDeserializer.vanillaDeserialize(BeanDeserializer.java:283) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:287) ~[graylog.jar:?]
        ... 10 more
I am using aws plugin to get cloud trail logs from aws, but it fails for some logs
Graylog version : 2.4.6
