Graylog Version: Graylog 2.1.2+50e449a on ip-x.x.x.x-us-west-2.compute.internal (Oracle Corporation 1.8.0_101 on Linux 4.9.62-21.56.amzn1.x86_64)
Below error is flooded in graylog-server.log.
2017-11-30 08:29:04,434 ERROR: org.graylog.aws.inputs.cloudtrail.CloudTrailSubscriber - Could not read CloudTrail log file for <tr-dev-cloudtrial-all>. Skipping.
com.fasterxml.jackson.databind.JsonMappingException: Unexpected end-of-input: was expecting closing quote for a string value
at [Source: java.io.StringReader@4fcc6d68; line: 1, column: 10021316]
at [Source: java.io.StringReader@4fcc6d68; line: 1, column: 9999992] (through reference chain: org.graylog.aws.inputs.cloudtrail.json.CloudTrailRecordList["Records"]->java.util.ArrayList[8190]->org.graylog.aws.inputs.cloudtrail.json.CloudTrailRecord["userIdentity"]->org.graylog.aws.inputs.cloudtrail.json.CloudTrailUserIdentity["sessionContext"])
at com.fasterxml.jackson.databind.JsonMappingException.wrapWithPath(JsonMappingException.java:378) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.JsonMappingException.wrapWithPath(JsonMappingException.java:338) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.BeanDeserializerBase.wrapAndThrow(BeanDeserializerBase.java:1510) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.BeanDeserializer.vanillaDeserialize(BeanDeserializer.java:262) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.BeanDeserializer.deserialize(BeanDeserializer.java:125) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.SettableBeanProperty.deserialize(SettableBeanProperty.java:490) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.impl.FieldProperty.deserializeAndSet(FieldProperty.java:101) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.BeanDeserializer.vanillaDeserialize(BeanDeserializer.java:260) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:277) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:249) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:26) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:3807) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:2797) ~[graylog.jar:?]
at org.graylog.aws.inputs.cloudtrail.messages.TreeReader.read(TreeReader.java:20) ~[graylog-plugin-aws-1.2.0.jar:?]
at org.graylog.aws.inputs.cloudtrail.CloudTrailSubscriber.run(CloudTrailSubscriber.java:107) [graylog-plugin-aws-1.2.0.jar:?]
Caused by: com.fasterxml.jackson.core.JsonParseException: Unexpected end-of-input: was expecting closing quote for a string value
at com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:1586) ~[graylog.jar:?]
at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:521) ~[graylog.jar:?]
at com.fasterxml.jackson.core.base.ParserMinimalBase._reportInvalidEOF(ParserMinimalBase.java:458) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._skipString(ReaderBasedJsonParser.java:2005) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextToken(ReaderBasedJsonParser.java:599) ~[graylog.jar:?]
at com.fasterxml.jackson.core.base.ParserMinimalBase.skipChildren(ParserMinimalBase.java:147) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.BeanDeserializerBase.handleUnknownProperty(BeanDeserializerBase.java:1380) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.BeanDeserializerBase.handleUnknownVanilla(BeanDeserializerBase.java:1366) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.BeanDeserializer.vanillaDeserialize(BeanDeserializer.java:266) ~[graylog.jar:?]
... 16 more
2017-11-30 08:29:04,736 ERROR: org.graylog.aws.inputs.cloudtrail.CloudTrailSubscriber - Could not read CloudTrail log file for <tr-dev-cloudtrial-all>. Skipping.
com.fasterxml.jackson.databind.JsonMappingException: Unexpected end-of-input: was expecting closing '"' for name
at [Source: java.io.StringReader@746eff93; line: 1, column: 10021316]
at [Source: java.io.StringReader@746eff93; line: 1, column: 9999984] (through reference chain: org.graylog.aws.inputs.cloudtrail.json.CloudTrailRecordList["Records"]->java.util.ArrayList[8145])
at com.fasterxml.jackson.databind.JsonMappingException.wrapWithPath(JsonMappingException.java:350) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:298) ~[graylog.jar:?]
Caused by: com.fasterxml.jackson.core.JsonParseException: Unexpected end-of-input: was expecting closing '"' for name
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._parseName2(ReaderBasedJsonParser.java:1646) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._parseName(ReaderBasedJsonParser.java:1630) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextFieldName(ReaderBasedJsonParser.java:872) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.BeanDeserializer.vanillaDeserialize(BeanDeserializer.java:267) ~[graylog.jar:?]
... 10 more
Please help/suggest on how to fix this error.
Regards,
Amit.
