I noticed this after updating to 4.2.9 today (unsure if this was a prior issue, but unlikely). I have 3 nodes in a cluster with 1 being a voting-only. Master node works fine and all inputs start with no issue
2022-05-24T10:57:43.923-07:00 INFO [CloudTrailTransport] Starting cloud trail subscriber
2022-05-24T10:57:43.924-07:00 INFO [InputStateListener] Input [AWS CloudTrail/61955be4763c9f3c3d36f5f4] is now STARTING
2022-05-24T10:57:44.064-07:00 INFO [InputStateListener] Input [AWS CloudTrail/61955be4763c9f3c3d36f5f4] is now RUNNING
Second node is having issues that seem to be java related. All components in the cluster have identical versions including java
org.graylog2.shared.inputs.NoSuchInputTypeException: There is no input of type <org.graylog.aws.inputs.cloudtrail.CloudTrailInput> registered.
at org.graylog2.shared.inputs.MessageInputFactory.create(MessageInputFactory.java:41) ~[graylog.jar:?]
at org.graylog2.inputs.InputServiceImpl.getMessageInput(InputServiceImpl.java:381) ~[graylog.jar:?]
at org.graylog2.inputs.InputEventListener.startInput(InputEventListener.java:107) [graylog.jar:?]
at org.graylog2.inputs.InputEventListener.inputCreated(InputEventListener.java:74) [graylog.jar:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:87) [graylog.jar:?]
at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:144) [graylog.jar:?]
at com.google.common.eventbus.Subscriber$1.run(Subscriber.java:72) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
at java.lang.Thread.run(Thread.java:829) [?:?]
AWS input working? if so are you able to see this INPUT configured on this second node?
It seams that there is something missing or the node with the issue didn’t get updated correctly.
By chance is this only one node having issue?
Have you tried to recreate AWS input?
it is the only node having the issue. the last commit to this class is here: Load AWS plugin on all nodes by thll · Pull Request #652 · Graylog2/graylog-plugin-aws · GitHub
it kind of sheds some light on it i guess. once i downgraded back to 4.0.16 the issue went away, but 4.2.5+ produce the problem, though i havent tried all patches in 4.2.
All other AWS inputs for Kinesis/Cloudwatch work fine in 4.2.9
I did try to recreate it but unless its on the Master node if fails, however, a temporary workaround seems to be only having it run on the Master node, but that doesnt seem ideal.
I upgraded to 4.3 since that pull request mentioned it would be released then, but that ended up causing all kinds of MongoDB issues which resulted in me having to rollback from snapshots…once i finally got it back up and running i called it a day.
I completed understand, this is starting to sound like a bug but if the other node (#3) is not having this issue I’m wondering why only the #2 node is…
Just an idea, maybe upgrade in order → 4.0 → 4.1 then to 4.2.
to clarify i have 3 nodes. 1 master, 1 slave, and 1 voting-only (ES and Mongo only)
just discovered going from 4.0.16 to 4.1.0-4 produces the same issue…now im really confused at whats happening.
Just an FYI, I found this in the doc’s here .
This part:
is_leader = true
If you are running more than one instance of Graylog server you have to select only one graylog-servernode as the leader.
This node will perform periodical and maintenance actions that replica nodes won’t.
Replica nodes will accept messages just the same as leader nodes.
Nodes will fall back to replica mode if there already is a leader in the cluster.
