Hello all.
I am running a containerized Graylog deployment inside a Kubernetes cluster.
Due to some restrictions, I am unable to use TCP or UDP inputs.
The question I have is how do I expose the GELF HTTP input outside the cluster, so I can send my logs via HTTP from an external application?
I thought about using Ingress, but I am unsure about the configuration (what is the service it should point to) and also the helm chart configuration for Graylog.
Can I use the same service used to expose the web interface, only on a different port?
Thank you!
