Errors with new Graylog installation
Unable to get new Graylog installation functional. I Get 3 errors shown in following screenshot.
I used the following guide for the installation:
  • OS Information:
Debian GNU/Linux 12 (bookworm)
MongoDB: 7.0.15
Openjdk-17-jdk: 17.0.13+11-2
Opensearch: 7.10.2
Java: 17.10.13
  • Package Version:
Graylog-datanode: 6.1.3-1
Graylog-server: 6.1.3-1
Selection from var/log/graylog-server/server.log
1) [Guice/ErrorInjectingConstructor]: IllegalArgumentException: Illegal base64 character 2d
  at CustomCAX509TrustManager.<init>(CustomCAX509TrustManager.java:42)
  while locating CustomCAX509TrustManager
  at ServerPreflightChecksModule.configure(ServerPreflightChecksModule.java:44)
  while locating X509TrustManager
cat /etc/graylog/server/server.conf | egrep -v “^\s*(#|$)”
password_secret = XXXXXXXXX
root_password_sha2 = XXXXXXXXX
http_bind_address = 192.168.80.109:9000
disabled_retention_strategies = none,close
allow_highlighting = false
field_value_suggestion_mode = on
output_batch_size = 500
output_flush_interval = 1
ring_size = 65536
inputbuffer_ring_size = 65536
integrations_scripts_dir = /usr/share/graylog-server/scripts
*Google searches. I found similar issues in forums including this one, but didn’t find a solution.
*Guide did not mention Java as a dependency, so uninstalled Graylog, installed Java and reinstalled Graylog.
*Original password_secret contained dashes. Tried replacing with zeros for RFC 4648 compatibility, but still face the same issue.
Does anyone have any hints as to what may be causing these errors? Thanks in advance.
Can you also post your datanode config file? Also is datanode snd graylog on the same machine different machines etc?
Both datanode and graylog are installed on the same machine.
cat /etc/graylog/datanode/datanode.conf | egrep -v “^\s*(#|$)”
node_id_file = /etc/graylog/datanode/node-id
config_location = /etc/graylog/datanode
opensearch_location = /usr/share/graylog-datanode/dist
opensearch_config_location = /var/lib/graylog-datanode/opensearch/config
opensearch_data_location = /var/lib/graylog-datanode/opensearch/data
opensearch_logs_location = /var/log/graylog-datanode/opensearch
