Generally don’t have any issues with collector and nxlog but for some reason am getting the following error after first load. Loads fine after install with our configs.
Then at reload we are now getting this error in both the nxlog and sidecar logs.
Sidecar error
"level=error msg="[nxlog] Error during configuration validation: 2018-03-29 13:51:13 ERROR Failed to load
module from C:/msys/1.0\\extension\\xm_gelf.dll, The specified module could not be found. ; The specified
module could not be found. \r\r\n"
NXLOG Error
nxlog failed to start: Failed to load module from C:/msys/1.0\extension\xm_gelf.dll, The specified module
could not be found.
Nothing changes. No config alterations etc. Just reloading sidecar. What is with that path in the error? never seen that path nor does it or has it ever existed. Have checked in on the nxlog community but no answers there yet.
Thanks.
