Elasticsearch start fail
in graylog 3.0
i want to move /var/lib/elasticsearch to nfs
here is my step
stop graylog
stop elasticsearch
stop mongodb
mv /var/lib/elasticsearch /mnt/nfs/elasticsearch
after that
elasticsearch start fail
i try to
chown -R elasticsearch:elasticsearch /mnt/nfs/elasticsearch
chmod -R 777 /mnt/nfs/elasticsearch
elasticsearch still start fail
any one helps
thanks very much
Don’t. Just don’t. NFS is not made to hold Elasticsearch’s data.
//Did you tell the new location to elasticsearch?
Also as @benvanstaveren mentioned, don’t use NFS for store local database.
If you do a little research almost of the hits are performance problems…
https://www.google.com/search?q=elasticsearch+over+nfs&ie=utf-8&oe=utf-8&client=firefox-b-ab
