ElasticSearch wont stay running
Hi All,
I recently added a disk to our ubuntu VM running graylog as i needed more space for my elasticsearch.
I have completed the data transfer and updated the elasticsearch.yml to reflect the new location however the service just wont stay started.
Below is the logs I have a long with the result I get for a service status check. Would appear to be a permissions issue, what permissions should be set? I have alloweed all users full access, I believe.
Any assistance would be greatly appreciated.
root@POR-GRAYLOG:/usr/share/elasticsearch/bin# service elasticsearch status
● elasticsearch.service - Elasticsearch
Loaded: loaded (/usr/lib/systemd/system/elasticsearch.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2020-10-21 12:13:40 BST; 13s ago
Docs: http://www.elastic.co
Process: 29477 ExecStart=/usr/share/elasticsearch/bin/elasticsearch -p ${PID_DIR}/elasticsearch.pid --quiet (code=exi
Main PID: 29477 (code=exited, status=1/FAILURE)
Oct 21 12:13:35 POR-GRAYLOG systemd[1]: Started Elasticsearch.
Oct 21 12:13:35 POR-GRAYLOG elasticsearch[29477]: warning: Falling back to java on path. This behavior is deprecated. S
Oct 21 12:13:40 POR-GRAYLOG systemd[1]: elasticsearch.service: Main process exited, code=exited, status=1/FAILURE
Oct 21 12:13:40 POR-GRAYLOG systemd[1]: elasticsearch.service: Failed with result ‘exit-code’.
lines 1-11/11 (END)
[2020-10-21T12:07:32,020][ERROR][o.e.b.Bootstrap          ] [unknown] Exception
java.lang.IllegalStateException: Unable to access 'path.data' (/media/ubuntuadmin/Data/GrayLogData/elasticsearch)
	at org.elasticsearch.bootstrap.FilePermissionUtils.addDirectoryPath(FilePermissionUtils.java:70) ~[elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.bootstrap.Security.addFilePermissions(Security.java:299) ~[elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.bootstrap.Security.createPermissions(Security.java:254) ~[elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.bootstrap.Security.configure(Security.java:123) ~[elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:207) ~[elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:333) [elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:159) [elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:150) [elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:86) [elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:124) [elasticsearch-cli-6.8.4.jar:6.8.4]
	at org.elasticsearch.cli.Command.main(Command.java:90) [elasticsearch-cli-6.8.4.jar:6.8.4]
	at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:116) [elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:93) [elasticsearch-6.8.4.jar:6.8.4]
Caused by: java.nio.file.AccessDeniedException: /media/ubuntuadmin/Data/GrayLogData
	at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) ~[?:1.8.0_265]
	at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) ~[?:1.8.0_265]
	at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) ~[?:1.8.0_265]
	at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308) ~[?:1.8.0_265]
	at java.nio.file.Files.createDirectories(Files.java:746) ~[?:1.8.0_265]
	at org.elasticsearch.bootstrap.Security.ensureDirectoryExists(Security.java:413) ~[elasticsearch-6.8.4.jar:6.8.4]
	at org.elasticsearch.bootstrap.FilePermissionUtils.addDirectoryPath(FilePermissionUtils.java:68) ~[elasticsearch-6.8.4.jar:6.8.4]
	... 12 more
looks like ES data directory (/media/ubuntuadmin/Data/GrayLogData/elasticsearch) has incorrect permissions, or doesn’t exist and ES cannot create it under /media/ubuntuadmin/Data/GrayLogData
Thanks for taking the time to reply.
Any ideas on what the permissions should be? I can confirm the directory does exist using that path.
Thanks.
Yes, looks like a permission issue.
The folder should be owned by the user running the elasticsearch process
Thanks for clarifying.
How would I confirm which user account is running, or attempting to run that process?
ps -ef | grep elasticsearch
if you are running linux
This is what I get, any thoughts on which is wrong? or both!
Try looking in /usr/lib/systemd/system/elasticsearch.service.
In mine there’s a line that says User=elasticsearch which tells systemd to start Elasticsearch as the elasticsearch user.
