Please it is been 3 days that i’m stuck with this:
My elasticsearch.yml is :
# ======================== Elasticsearch Configuration =========================
# NOTE: Elasticsearch comes with reasonable defaults for most settings.
# Before you set out to tweak and tune the configuration, make sure you
# understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.elastic.co/guide/en/elasticsearch/reference/index.html
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
cluster.name: my-application
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
node.name: node-1
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
path.data: /data/elasticsearch
# Path to log files:
#path.logs: /path/to/logs
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
network.host: 0.0.0.0
# Set a custom port for HTTP:
#http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when new node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
discovery.zen.ping.unicast.hosts: ["172.16.250.30"]
# Prevent the "split brain" by configuring the majority of nodes (total number of master-eligible nodes / 2 + 1):
#discovery.zen.minimum_master_nodes: 3
# For more information, consult the zen discovery module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
elasticsearch logs :
Caused by: java.nio.file.AccessDeniedException: /data/elasticsearch
at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) ~[?:1.8.0_171]
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) ~[?:1.8.0_171]
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) ~[?:1.8.0_171]
at sun.nio.fs.UnixFileSystemProvider.createDirectory(UnixFileSystemProvider.java:384) ~[?:1.8.0_171]
at java.nio.file.Files.createDirectory(Files.java:674) ~[?:1.8.0_171]
at java.nio.file.Files.createAndCheckIsDirectory(Files.java:781) ~[?:1.8.0_171]
at java.nio.file.Files.createDirectories(Files.java:767) ~[?:1.8.0_171]
at org.elasticsearch.bootstrap.Security.ensureDirectoryExists(Security.java:492) ~[elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.bootstrap.Security.addPath(Security.java:448) ~[elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.bootstrap.Security.addFilePermissions(Security.java:291) ~[elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.bootstrap.Security.createPermissions(Security.java:246) ~[elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.bootstrap.Security.configure(Security.java:119) ~[elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:228) ~[elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:342) ~[elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:132) ~[elasticsearch-5.6.10.jar:5.6.10]
... 6 more
Graylog logs :
2018-06-18T16:41:48.973+02:00 ERROR [Messages] Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #11).
2018-06-18T16:41:50.899+02:00 ERROR [Messages] Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #12).
2018-06-18T16:41:50.906+02:00 ERROR [Messages] Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #12).
2018-06-18T16:41:51.043+02:00 ERROR [Messages] Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #12).
2018-06-18T16:41:55.023+02:00 ERROR [Messages] Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #13).
2018-06-18T16:41:55.027+02:00 ERROR [Messages] Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #13).
2018-06-18T16:41:55.168+02:00 ERROR [Messages] Caught exception during bulk indexing: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200, retrying (attempt #13).
2018-06-18T16:42:01.695+02:00 WARN [KafkaJournal] Journal utilization (103.0%) has gone over 95%.
2018-06-18T16:42:01.995+02:00 INFO [MongoIndexSet] Did not find a deflector alias. Setting one up now.
2018-06-18T16:42:02.008+02:00 INFO [MongoIndexSet] There is no index target to point to. Creating one now.
2018-06-18T16:42:02.030+02:00 INFO [MongoIndexSet] Cycling from <none> to <graylog_0>.
2018-06-18T16:42:02.030+02:00 INFO [MongoIndexSet] Creating target index <graylog_0>.
2018-06-18T16:42:06.458+02:00 INFO [Indices] Successfully created index template graylog-internal
2018-06-18T16:42:41.795+02:00 INFO [MongoIndexSet] Waiting for allocation of index <graylog_0>.
2018-06-18T16:43:01.695+02:00 WARN [KafkaJournal] Journal utilization (103.0%) has gone over 95%.
2018-06-18T16:43:01.787+02:00 INFO [Messages] Bulk indexing finally successful (attempt #14).
2018-06-18T16:43:01.840+02:00 INFO [KafkaJournal] Read offset 33546783 before start of log at 33901794, starting to read from the beginning of the journal.
2018-06-18T16:43:01.857+02:00 INFO [Messages] Bulk indexing finally successful (attempt #14).
2018-06-18T16:43:01.904+02:00 INFO [MongoIndexSet] Index <graylog_0> has been successfully allocated.
2018-06-18T16:43:01.904+02:00 INFO [MongoIndexSet] Pointing index alias <graylog_deflector> to new index <graylog_0>.
Permissions :
f: /data/elasticsearch
dr-xr-xr-x root root /
drwxrwxrwx log-admin log-admin data
drwxr-x--- elasticsearch elasticsearch elasticsearch
