Opensearch Cluster Configuration
Hey Guys Im trying to set up a opensearch cluster for my new Multi node setup. But i have a few problems with the configuration of the opensearch nodes to create a cluster.
I work on a Debian 12
Have installed opensearch 2.13.0
(on 2.15.0 my config worked properly but Graylog only supports 2.13.0)
Opensearch Node conf
# ======================== OpenSearch Configuration =========================
# NOTE: OpenSearch comes with reasonable defaults for most settings.
#       Before you set out to tweak and tune the configuration, make sure you
#       understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.opensearch.org
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
cluster.name: graylog
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
node.name: DB16
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
path.data: /var/lib/opensearch
# Path to log files:
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# OpenSearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
network.host: 0.0.0.0
# Set a custom port for HTTP:
#http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when this node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
node.roles: [ master, data, ingest ]
discovery.seed_hosts: ["db15.example.intern", "db16.example.intern", "db17.example.intern"]
# Bootstrap the cluster using an initial set of cluster-manager-eligible nodes:
cluster.initial_cluster_manager_nodes: ["db15.example.intern", "db16.example.intern", "db17.example.intern"]
# For more information, consult the discovery and cluster formation module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
# ---------------------------------- Remote Store -----------------------------------
# Controls whether cluster imposes index creation only with remote store enabled
# cluster.remote_store.enabled: true
# Repository to use for segment upload while enforcing remote store for an index
# node.attr.remote_store.segment.repository: my-repo-1
# Repository to use for translog upload while enforcing remote store for an index
# node.attr.remote_store.translog.repository: my-repo-1
# ---------------------------------- Experimental Features -----------------------------------
# Gates the visibility of the experimental segment replication features until they are production ready.
#opensearch.experimental.feature.segment_replication_experimental.enabled: false
# Gates the functionality of a new parameter to the snapshot restore API
# that allows for creation of a new index type that searches a snapshot
# directly in a remote repository without restoring all index data to disk
# ahead of time.
#opensearch.experimental.feature.searchable_snapshot.enabled: false
# Gates the functionality of enabling extensions to work with OpenSearch.
# This feature enables applications to extend features of OpenSearch outside of
# the core.
#opensearch.experimental.feature.extensions.enabled: false
# Gates the optimization of datetime formatters caching along with change in default datetime formatter
# Once there is no observed impact on performance, this feature flag can be removed.
#opensearch.experimental.optimization.datetime_formatter_caching.enabled: false
# Gates the functionality of enabling Opensearch to use pluggable caches with respective store names via setting.
#opensearch.experimental.feature.pluggable.caching.enabled: false
######## Start OpenSearch Security Demo Configuration ########
# WARNING: revise all the lines below before you go into production
plugins.security.ssl.transport.pemcert_filepath: esnode.pem
plugins.security.ssl.transport.pemkey_filepath: esnode-key.pem
plugins.security.ssl.transport.pemtrustedcas_filepath: root-ca.pem
plugins.security.ssl.transport.enforce_hostname_verification: false
plugins.security.ssl.http.enabled: true
plugins.security.ssl.http.pemcert_filepath: esnode.pem
plugins.security.ssl.http.pemkey_filepath: esnode-key.pem
plugins.security.ssl.http.pemtrustedcas_filepath: root-ca.pem
plugins.security.allow_unsafe_democertificates: true
plugins.security.allow_default_init_securityindex: true
plugins.security.authcz.admin_dn: ['CN=kirk,OU=client,O=client,L=test,C=de']
plugins.security.audit.type: internal_opensearch
plugins.security.enable_snapshot_restore_privilege: true
plugins.security.check_snapshot_restore_write_privileges: true
plugins.security.restapi.roles_enabled: [all_access, security_rest_api_access]
plugins.security.system_indices.enabled: true
plugins.security.system_indices.indices: [.plugins-ml-agent, .plugins-ml-config, .plugins-ml-connector,
  .plugins-ml-controller, .plugins-ml-model-group, .plugins-ml-model, .plugins-ml-task,
  .plugins-ml-conversation-meta, .plugins-ml-conversation-interactions, .plugins-ml-memory-meta,
  .plugins-ml-memory-message, .plugins-ml-stop-words, .opendistro-alerting-config,
  .opendistro-alerting-alert*, .opendistro-anomaly-results*, .opendistro-anomaly-detector*,
  .opendistro-anomaly-checkpoints, .opendistro-anomaly-detection-state, .opendistro-reports-*,
  .opensearch-notifications-*, .opensearch-notebooks, .opensearch-observability, .ql-datasources,
  .opendistro-asynchronous-search-response*, .replication-metadata-store, .opensearch-knn-models,
  .geospatial-ip2geo-data*, .plugins-flow-framework-config, .plugins-flow-framework-templates,
  .plugins-flow-framework-state]
node.max_local_storage_nodes: 3
######## End OpenSearch Security Demo Configuration ########
The configuration is the same on all node (except for the host name)
When i try to check the cluster with:
curl -XGET https://db16.example.intern:9200/_cat/nodes?v -u 'admin:<Password>' --insecure
I get:
curl: (35) OpenSSL/3.0.13: error:0A00010B:SSL routines::wrong version number
With
curl -X GET "http://db16.example.intern:9200/_cat/nodes?v"
I get:
{"error":{"root_cause":[{"type":"cluster_manager_not_discovered_exception","reason":null}],"type":"cluster_manager_not_discovered_exception","reason":null},"status":503}
I hope anybody can help me.
Greetings
Could this be the bind addres 0.0.0.0 that is all listening interfaces and should
be set to the hosts ip addres.
Is 9200 listening at 0.0.0.0 ?
What happens when you remove the comment here:
#http.port: 9200
grafik
I also can curl all nodes from each other
curl http://db15.example.intern:9200/
grafik
I found the failure:
node.name: DB16
#node.attr.rack: r1
# limit.
#http.port: 9200
node.roles: [ cluster_manager, data, ingest ]
cluster.initial_cluster_manager_nodes: ["DB15", "DB16", "DB17"]
# ahead of time.
# the core.
the master is called cluster_manager in this version and the cluster.initial_cluster_manager_nodes are given as hostname not as FQDN or IP
