Hi, I have an OpenSearch 2.11 installation on AWS communicating with a GrayLog version 5.1 container. Any stream I try to open gives me this error:
Elasticsearch exception [type=illegal_argument_exception, reason=key [types] is not supported in the metadata section]
After some online research I followed the advice to set the compatibility.override_main_response_version variable to false, but this, in addition to not solving the problem, causes an error in GrayLog setup, so this solution didn’t work for me.
