ERROR: Unsupported Elasticsearch version: 2.0.0 when using opensearch 2.9
I am trying to upgrade a graylog cluster from elasticsearch to opensearch 2.9.0
opensearch 2.9.0
  • OS Information:
    CentOS 7
  • Package Version:
    graylog-server-4.2.13-1.noarch
Please see the following link(s) to help you with this error:
Need further help?
Terminating. :frowning:
I upgraded graylog from 4.2 to 5.1.
I pointed to a brand new opensearch cluster (I’m okay with it deleting old indexes that are not found).
Is this a supported version of opensearch? Is it too new?
Can you share the full server.log?
Can you also share your server.conf file? (be sure to redact the admin password and password secret)
I suspect there may be something left behind in the server.conf for graylog but its difficult to know for certain without seeing it.
I can validate that graylog does run without issue with OpenSearch 2.9 as I am using that for my lab and have confirmed reports from others using it as well.
I solved this. I upgraded some of the nodes in my cluster to 5.1 but some got missed, and were still on 4.2
