OpenSearch versions
I wanted to upgrade our graylog cluster from 5.2 to 6.3. Went to check what packages were installed, and noticed that I had opensearch-2.18.0 installed. While reading the upgrade manual it says to not install any opensearch newer than 2.15.
My setup seems to work just fine, but I’m worried about losing the data.
  • OS Information: Ubuntu 22.04.5
  • Package Version: Graylog 5.2
How should I proceed to not loose any data with “too new” opensearch version?
There was a bug that effected some functionality in Graylog which is why we could not support several versions. However Graylog 6.2 and above will support opensearch 2.19.3 and (hopefully) above
