Before you post: Your responses to these questions will help the community help you. Please complete this template if you’re asking a support question. Don’t forget to select tags to help index your topic!
Hello Community,
I’m doing my Internal SOC project to build SIEM stacks using open-source tools and I decided to use Graylog as part of log aggregation. However, I also use Wazuh Manager to collects logs from the endpoint and would be forwarding those logs using fluent-bit to Graylog. But, I got an error on graylog as shows below:
While retrieving data for this widget, the following error(s) occurred:
Elasticsearch exception [type=illegal_argument_exception, reason=key [types] is not supported in the metadata section].
OS Information: Debian 11
Package Version: 5.1
Can you try removing “compatibility.override_main_response_version: true” from “/etc/wazuh-indexer/opensearch.yml” and restart the wazuh indexer and graylog?
How is it going in general for the Wazuh and Graylog setup?
I am also running into other problems.
For example: Wazuh dashboard are created based on field names with a dot separator and Graylog does not supports this currently. Graylog replaces the dot from the json extractor before it forwards in into the Opensearch index.
Also when removing the “compatibility.override_main_response_version: true” option from the wazuh-indexer breaks the filebeat ingestion. A combination of filebeat for Wazuh alerts and Graylog for other inputs seems not possible on this moment.
I am using fluent-bit to forward logs. I am following below blog to setup the SOC.
Currently I am facing Wazuh API connection error.
INFO: No current API selected
INFO: Getting API hosts…
INFO: API hosts found: 1
INFO: Checking API host id [default]…
INFO: Could not connect to API id [default]: 3099 - ERROR3099 - Wazuh not ready yet
INFO: Removed [navigate] cookie
ERROR: No API available to connect
