Your responses to these questions will help the community help you. Please complete this template if you’re asking a support question.
I’m integrating Wazuh → Fluent-bit → Graylog, everything is configured, In graylog configure this input:
bind_address: 0.0.0.0
charset_name: UTF-8
max_message_size: 2097152
number_worker_threads: 4
override_source: <empty>
port: 5555
recv_buffer_size: 1048576
tcp_keepalive: false
tls_cert_file: <empty>
tls_client_auth: disabled
tls_client_auth_cert_file: <empty>
tls_enable: false
tls_key_file: <empty>
tls_key_password:********
use_null_delimiter: false
i see data getting in but i get this message
While retrieving data for this widget, the following error(s) occurred:
Elasticsearch exception [type=illegal_argument_exception, reason=key [types] is not supported in the metadata section].
when i look the /var/log/graylog-server/server.log it shows:
2024-04-26T20:32:12.759Z WARN [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: IOException[Unable to parse response body for Response{requestLine=POST /_bulk?timeout=1m HTTP/1.1, host=htt
ps://wazuh-indexer-01.home.lab:9200, response=HTTP/1.1 200 OK}]; nested: NullPointerException;, errorDetails=[]}, retrying (attempt #244).
2024-04-26T20:32:38.426Z WARN [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: IOException[Unable to parse response body for Response{requestLine=POST /_bulk?timeout=1m HTTP/1.1, host=htt
ps://wazuh-indexer-03.home.lab:9200, response=HTTP/1.1 200 OK}]; nested: NullPointerException;, errorDetails=[]}, retrying (attempt #235).
2024-04-26T20:32:42.787Z WARN [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: IOException[Unable to parse response body for Response{requestLine=POST /_bulk?timeout=1m HTTP/1.1, host=htt
ps://wazuh-indexer-02.home.lab:9200, response=HTTP/1.1 200 OK}]; nested: NullPointerException;, errorDetails=[]}, retrying (attempt #245).
- OS Information:
root@graylog:/etc/graylog/server# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
- Package Version:
graylog-5.1-repository 1-2
graylog-server 5.1.13-1
mongodb-database-tools 100.9.4
mongodb-mongosh 2.2.5
mongodb-org 6.0.15
mongodb-org-database 6.0.15
mongodb-org-database-tools-extra 6.0.15
mongodb-org-mongos 6.0.15
mongodb-org-server 6.0.15
mongodb-org-shell 6.0.15
mongodb-org-tools 6.0.15
- Service logs, configurations, and environment variables:
server.conf:
is_leader = true
password_secret = password_secret
root_username = admin
root_password_sha2 = root_password
elasticsearch_hosts = https://graylog:passwd!@wazuh-indexer-01.home.lab:9200,https://graylog:passwd!@wazuh-indexer-02.home.lab:9200,https://graylog:passwd!@wazuh-indexer-03.home.lab:9200
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
point out where is the error, I have no clue where could be the problem.
