Display thousands separator in aggregation tables?
Hi Graylog community,
Is it possible to display a thousands separator in aggregation tables? For example when I’m doing “top talkers” reports it’s nearly impossible to read without the thousands being separated.
This is what it looks like for example:
It would be great if it would be easier to read.
Best Regards,
Michael
Do you have idea how could be this? If you make suggestion maybe the developers can help a more. Please help them, to be able to help on us.
Not sure if I understand what you are asking.
The numbers are very difficult to read and I was asking if there is a way to display a thousands separator, basically instead of showing 4964559505 it would be so much easier to read if it was showing 4.964.559.505 or 4,964,559,505 or 4 964 559 505.
My question is if it is possible to enable this (for example a setting in the config somehwere which I’m not aware of).
ah…
I misunderstand your question.
It is clear for me now.
Maybe @konrad plan it in the next updates.
Thanks for pointing this out. I will create an issue. I make no promises for the upcoming release, since we are already trying to finish it, but I see the need for that!
Thanks @macko003 and @Mike_FUT
Here the issue: https://github.com/Graylog2/graylog2-server/issues/7831
Please comment if you find something missing.
- Konrad
Thanks, I upload the picture, to make the problem clear.
