I want to split comma separated message,and extract the amount field to be aggregated and create dashboard
You can do that with a pipeline and likely get close to what you want in a dashboard.
We would give you more information, but you didn’t give us much to go on.
What do you think we should know about your environment and more specifically about the inputs and expected outputs relative to your question?
