Split comma separated message and create dashboard
I want to split below message and take the 10th field and create dashboard aggregating the sum of this amount,could you please share the steps:
1751527842,148758670380,201179008308,20190617,0,6177,0.0000,0.0000,0.0000,92,0,2019061713065108,4,46980,0,120,21121506888,20117900830802,201121506888,201127272290,43,116,6,;
  1. create regex that extract the 10th field
  2. create a dashboard
  3. create a search that contains the in 1. extracted field
  4. create a widget with the aggregation
thank you for your reply ,can you send the steps for applying the regex on graylog to see the field in the message details to create the dashboard?
use the extractors or the processing pipelines:
http://docs.graylog.org/en/3.0/pages/extractors.html
http://docs.graylog.org/en/3.0/pages/pipelines.html
If you want me todo your work, I need your PayPal Adress that I can request the Money for that from you.
