Split huge message to multiple small
Hi, how I can split huge nested json message with repeatable fields on input to multiple messages?
This is my json:
        "Level": "Information",
        "Date": "2021-07-24T04:01:21",
        "Server": "srv"
        "Server": ""
        "Date": "2021-07-24T04:01:27",
        "Server": "srv"
        "Server": "srv"
Hello && Welcome
I would like to help with your issue but I’m not sure what’s going on.
Can you have a look here.
With that added information it will help troubleshoot your issue and you will get a quicker response from the other community members.
Thank you
Problem description
Hello i edited and i have a problem with huge messages from RabbitMQ on Raw/Plaintext AMQP Graylog input.The problem is in the huge received nested json with repeatable key names on graylog input. I want to split this huge json message to multiple small messages on Raw/Plaintext AMQP Graylog input and sight his in search table as separated messages.
Steps to try resolve problem
To separate messages I’m tried use input extractors but I didn’t get anything.
This is part of my json:
        "Server": "srv"
        "Server": ""
        "Server": "srv"
        "Server": "srv"
