Disable graylog custom alert conditions plugins
I have 3 custom Graylog alert conditions and 1 alert notification plugin that I have added to my Graylog. I have about 100 alert conditions based on these plugins. I want to temporarily disable them to test my Graylog output performance.
How can I disable the plugins with minimum changes? Do I have to delete all the alert conditions before I remove the plugins from the directory? Will the alert conditions throw errors if the plugins are removed or removing the plugins will disable the alert conditions and alert notifications temporarily?
without knowing the details and looking into them that is not easy to answer. You might be able to just move them out of the plugin folder and restart Graylog.
In the end it might show some errors, but graylog should run. But, that is not tested as we do not know what you have in your environment.
