Completely disable plugins
Hi, just upgraded to 2.4, everything is OK.
Time ago I want to completely disable plugins, is there any option in the configuration to selectively disable some of them? For example, I will never use the AWS plugin, or the geolocation or the Threat Intelligence Lookup.
You can remove the respective JAR files from the plugin_dir of your Graylog node(s).
Disabling plugins via the Graylog REST API or the web interface is currently not possible.
Thanks, the problem is that after a new upgrade, the plugins would be reactivated, right?
Yes, you would have to remove the plugins again after you’ve updated the Graylog package.
