Plugin Installation Problem
Hi All
In my Environment we have 7 Gl-Data Nodes and one interface Node. I just want to know suppose I want to use Plugin graylog-plugin-alert-conditional-count-0.0.1.jar so I need to put .jar file only on interface node or every data nodes?
Graylog Version - 2.4.7
Elasticsearch Version - 5.6
depending on the plugin, but I would advice to place that on every node.
Short Question, why did you open new topics when you have nearly the same question in other topics already asked?
Thanks @jan for the info.
What if I have notification Plugin like slack? Need to do for all nodes or only web-interface node?
And sorry @jan By mistake I have created the same topic will remember from next time.
