hey everyone,
i want to depoly graylog with its dependecies ( opensearch and mongodb) in kubernetes but i cant find a reasonable guide for the depolyment, can someone help me please.
hey everyone,
ChatGPT answer for you
Deploying Graylog with OpenSearch and MongoDB on Kubernetes is absolutely doable, but you’re right — official, consolidated documentation is limited. Here’s a practical and reasonably production-ready guide to help you deploy the entire Graylog stack in Kubernetes, step-by-step.
You will deploy:
kubectl configuredhelm installed (for MongoDB & OpenSearch)bash
CopyEdit
helm repo add bitnami https://charts.bitnami.com/bitnami
helm repo update
helm install mongodb bitnami/mongodb --set auth.enabled=false
Disable auth for simplicity (you can secure it later). This will expose MongoDB on a ClusterIP service named
mongodb.
OpenSearch doesn’t yet have an official Helm chart, but the opensearch-project/helm-charts is the go-to.
bash
CopyEdit
git clone https://github.com/opensearch-project/helm-charts.git
cd helm-charts/charts/opensearch
helm dependency update
helm install opensearch . --set singleNode=true
This installs OpenSearch in single-node mode for dev/test. For production, set up multi-node.
Unfortunately, there’s no official Graylog Helm chart. But here’s how to deploy Graylog using a Kubernetes Deployment + Service.
yaml
CopyEdit
# graylog-configmap.yaml
apiVersion: v1
kind: ConfigMap
metadata:
data:
graylog.conf: |
is_master = true
node_id_file = /usr/share/graylog/data/config/node-id
password_secret = changemechangemechangeme
root_password_sha2 = <your-root-password-sha256>
root_username = admin
http_external_uri = http://localhost:9000/
mongo_uri = mongodb://mongodb:27017/graylog
opensearch_hosts = http://opensearch-cluster-master:9200
Generate a SHA-256 hash of your admin password:
bash
CopyEdit
echo -n yourpassword | sha256sum
yaml
CopyEdit
# graylog-deployment.yaml
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
replicas: 1
selector:
matchLabels:
app: graylog
template:
metadata:
labels:
app: graylog
spec:
containers:
- name: graylog
image: graylog/graylog:5.2
ports:
- containerPort: 9000
- containerPort: 12201
- containerPort: 1514
env:
- name: GRAYLOG_SERVER_CONF
value: /usr/share/graylog/config/graylog.conf
volumeMounts:
- name: config-volume
mountPath: /usr/share/graylog/config
volumes:
configMap:
yaml
CopyEdit
# graylog-service.yaml
apiVersion: v1
kind: Service
metadata:
spec:
selector:
app: graylog
ports:
- protocol: TCP
port: 9000
targetPort: 9000
- protocol: TCP
port: 12201
targetPort: 12201
- protocol: TCP
port: 1514
targetPort: 1514
type: LoadBalancer # or NodePort if LoadBalancer not supported
Apply your configs:
bash
CopyEdit
kubectl apply -f graylog-configmap.yaml
kubectl apply -f graylog-deployment.yaml
kubectl apply -f graylog-service.yaml
Once deployed, access Graylog:
bash
CopyEdit
kubectl get svc graylog
EXTERNAL-IP:9000 in your browser.
