Graylog version 3
Elastic search 6.5
I am running graylog helm chart to setup graylog in kubernetes. but i am getting error in when i do kubectl get describe pod <>
error is : Readiness probe failed: Get http://10.8.2.67:9000/api/system/lbstatus: dial tcp 10.8.2.67:9000: connect: connection refused
After very long time pod is starting but still slave if not working and in master log i have found one issue
2019-05-03 06:27:29,576 ERROR: org.graylog2.indexer.fieldtypes.IndexFieldTypePoller - Couldn't get mapping for index <graylog_0>: null
2019-05-03 06:27:31,277 ERROR: org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical - Couldn't update field types for index set <Default index set/5ccaa268d1c68b000e51e3f4>
com.mongodb.MongoInterruptedException: Interrupted acquiring a permit to retrieve an item from the pool
while my slave is not staring only.
containers:
- name: graylog-master
image: "graylog/graylog:3.0.1"
securityContext:
privileged: true
runAsUser: 1100
env:
- name: GRAYLOG_PASSWORD_SECRET
value: {{required "A valid .Values.graylog.passwordSecret entry required!" .Values.graylog.passwordSecret }}
- name: GRAYLOG_ROOT_PASSWORD_SHA2
value: {{ .Values.graylog.passwordSecret | sha256sum }}
- name: GRAYLOG_MONGODB_URI
value: "mongodb://{{ $mongodbServiceName }}-0.{{ $mongodbServiceName }}:27017/graylog?replicaSet=rs0"
- name: GRAYLOG_IS_MASTER
value: "true"
- name: GRAYLOG_ELASTICSEARCH_DISCOVERY_ZEN_PING_UNICAST_HOSTS
value: "{{ $elasticsearchServiceName }}-0.{{ $elasticsearchServiceName }}:9300"
- name: GRAYLOG_ELASTICSEARCH_HOSTS
value: "http://{{ $elasticsearchServiceName }}-0.{{ $elasticsearchServiceName }}:9200"
- name: GRAYLOG_HTTP_PUBLISH_URI
value: "https://<MY URL>"
- name: GRAYLOG_HTTP_EXTERNAL_URI
- name: GRAYLOG_SERVER_JAVA_OPTS
value: "-Xms1g -Xmx1g -XX:NewRatio=1 -XX:MaxMetaspaceSize=256m -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow"
ports:
- containerPort: {{ .Values.graylog.web.service.internalPort }}
- containerPort: 12201
- containerPort: 1514
volumeMounts:
- name: graylog-persistent-storage
mountPath: /usr/share/graylog/data/journal
subPath: graylog
resources:
{{ toYaml .Values.graylog.master.containers.resources | indent 12 }}
readinessProbe:
httpGet:
path: /api/system/lbstatus
port: {{ .Values.graylog.web.service.internalPort }}
initialDelaySeconds: 120
periodSeconds: 3
timeoutSeconds: 3
successThreshold: 1
failureThreshold: 4
In my slave just it is not master config change is there.
It is also giving error when it start ’ Index Rotation Problem!’ and slave is not working.
