Default streams without login
Hello, I wonder if it would be possible, in the same way you can do in Grafana for example, show some streams by default without having to login. Only in the case of login the user could see both the default streams and their own assigned by their role.
he @jmhostalet
it is not possible to access log data in Graylog without authentication.
