Dashboard with fields responseStatus_message and responseStatus_code not showing values to user operator
I created a Dashboard that shows data in table format with fields responseStatus_message and responseStatus_code. When I login with admin user, I can see the data in the Dashboard.
I shared this Dashboard with the user operator.
However when I login with operator / operator user, no data is visible in the Dashboard.
  • OS Information:
    Linux 5.15.0-127-generic
  • Package Version:
    Graylog 5.2.10+c04b5a4 on 44391070415e (Eclipse Adoptium 17.0.12 on Linux 5.15.0-127-generic)
Verified sharing, roles
Would be great if someone can share if they have faced such an issue and how they resolved.
You have to also share the stream that has the messages. sharing the dashboard only shares the dashboard, you have to also have access to the data to show on the dashboard, this also means that you can have the same dashboard show different data for different people.
