Couldn't collect indices for alias graylog_deflector
Hi Support,
I have problem for installation graylog 3.0 over Centos 8 with this error below:
After installation graylog I have error for message_jurnal, this error solve after change server.conf from data/jurnal to /var/lib/graylog-server/journal.
For now i got this error please help for resolve this error.
2020-06-11T23:12:37.116-04:00 ERROR [IndexFieldTypePollerPeriodical] Couldn’t update field types for index set <Default index set/5ee2f2a453802805f126da4a>
org.graylog2.indexer.ElasticsearchException: Couldn’t collect indices for alias graylog_deflector
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:52) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:63) ~[graylog.jar:?]
at org.graylog2.indexer.indices.Indices.aliasTarget(Indices.java:336) ~[graylog.jar:?]
at org.graylog2.indexer.MongoIndexSet.getActiveWriteIndex(MongoIndexSet.java:204) ~[graylog.jar:?]
at org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical.lambda$schedule$4(IndexFieldTypePollerPeriodical.java:201) ~[graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_252]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_252]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_252]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_252]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
Caused by: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://127.0.0.1:9200
at io.searchbox.client.http.JestHttpClient.execute(JestHttpClient.java:80) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:47) ~[graylog.jar:?]
… 11 more
Caused by: org.apache.http.conn.HttpHostConnectException: Connect to 127.0.0.1:9200 [/127.0.0.1] failed: Connection refused (Connection refused)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:159) ~[graylog.jar:?]
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:373) ~[graylog.jar:?]
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:381) ~[graylog.jar:?]
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237) ~[graylog.jar:?]
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185) ~[graylog.jar:?]
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111) ~[graylog.jar:?]
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185) ~[graylog.jar:?]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83) ~[graylog.jar:?]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108) ~[graylog.jar:?]
at io.searchbox.client.http.JestHttpClient.executeRequest(JestHttpClient.java:151) ~[graylog.jar:?]
at io.searchbox.client.http.JestHttpClient.execute(JestHttpClient.java:77) ~[graylog.jar:?]
… 11 more
Caused by: java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_252]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_252]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_252]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_252]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_252]
at java.net.Socket.connect(Socket.java:607) ~[?:1.8.0_252]
at org.apache.http.conn.socket.PlainConnectionSocketFactory.connectSocket(PlainConnectionSocketFactory.java:75) ~[graylog.jar:?]
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142) ~[graylog.jar:?]
… 11 more
Please give me your advice for some technical that can resolve that problem
Thanks and Best Regards,
Feterzon
he @feterzon
I can spot:
did you have Elasticsearch running on the default port on localhost?
Yes, i have install with default port
he @feterzon
is elasticsearch up and running and is no firewall rule blocking traffic?
this suggests that a service is not available, use curl commands to test the connectivity for all services
All the firewall rule has allow, but always error from start the servive
When we test the curl always refuse the connection
this means the service cannot be reached, you need to check and fix this first
