graylog is a great project!But we encountered some problems while using it!
We can’t collect logs now, we are prompted “Error starting index ranges recalculation for graylog_deflector” / "Could not create a job to start index ranges recalculation for graylog_deflector, reason: Error: cannot Post http: / /123.xx.xx.xx.59811/iwjnea97fnsa2/system/indices/ranges/graylog_deflector/rebuild(400) ",I want help from great engineers!Thanks!
thank you for your reply,We use version v2.3.1+9f2c6ef,We did not find server.log,We guess the problem of indexing, but I don’t know how to solve it!Thanks!
2019-12-02 09:13:08,848 INFO : org.graylog2.inputs.InputStateListener - Input [GELF UDP/5de46523467b8902f535a6da] is now FAILED
2019-12-02 09:13:58,481 INFO : org.graylog2.inputs.InputStateListener - Input [GELF UDP/5de46523467b8902f535a6da] is now STOPPING
2019-12-02 09:13:58,482 INFO : org.graylog2.inputs.InputStateListener - Input [GELF UDP/5de46523467b8902f535a6da] is now STOPPED
2019-12-02 09:13:58,483 INFO : org.graylog2.inputs.InputStateListener - Input [GELF UDP/5de46523467b8902f535a6da] is now TERMINATED
2019-12-02 09:15:04,466 INFO : org.graylog2.periodical.IndexRetentionThread - Elasticsearch cluster not available, skipping index retention checks.
2019-12-02 09:16:43,376 INFO : org.graylog2.rest.resources.dashboards.DashboardWidgetsResource - Deleted widget <151adad2-b880-47d7-b767-d6293538bbc4> from dashboard <5badecb4467b897c59afb5e4>. Reason: REST request.
2019-12-02 09:20:04,459 ERROR: org.graylog2.indexer.cluster.Cluster - Couldn’t read cluster health for indices [graylog_] (Could not connect to http://10.104.196.80:59898)
2019-12-02 09:20:04,459 INFO : org.graylog2.periodical.IndexerClusterCheckerThread - Indexer not fully initialized yet. Skipping periodic cluster check.
2019-12-02 09:20:04,464 INFO : org.graylog2.periodical.IndexRetentionThread - Elasticsearch cluster not available, skipping index retention checks.
2019-12-02 09:25:04,459 ERROR: org.graylog2.indexer.cluster.Cluster - Couldn’t read cluster health for indices [graylog_] (Could not connect to http://10.104.196.80:59898)
2019-12-02 09:25:04,459 INFO : org.graylog2.periodical.IndexerClusterCheckerThread - Indexer not fully initialized yet. Skipping periodic cluster check.
2019-12-02 09:25:04,463 INFO : org.graylog2.periodical.IndexRetentionThread - Elasticsearch cluster not available, skipping index retention checks.
2019-12-02 09:30:04,466 INFO : org.graylog2.periodical.IndexRetentionThread - Elasticsearch cluster not available, skipping index retention checks.
2019-12-02 09:35:04,465 INFO : org.graylog2.periodical.IndexRetentionThread - Elasticsearch cluster not available, skipping index retention checks.
2019-12-02 09:40:04,459 ERROR: org.graylog2.indexer.cluster.Cluster - Couldn’t read cluster health for indices [graylog_] (Could not connect to http://10.104.196.80:59898)
2019-12-02 09:40:04,459 INFO : org.graylog2.periodical.IndexerClusterCheckerThread - Indexer not fully initialized yet. Skipping periodic cluster check.
2019-12-02 09:40:04,464 INFO : org.graylog2.periodical.IndexRetentionThread - Elasticsearch cluster not available, skipping index retention checks.
2019-12-02 09:45:04,462 ERROR: org.graylog2.indexer.cluster.Cluster - Couldn’t read cluster health for indices [graylog_] (Could not connect to http://10.104.196.80:59898)
2019-12-02 09:45:04,462 INFO : org.graylog2.periodical.IndexRetentionThread - Elasticsearch cluster not available, skipping index retention checks.
2019-12-02 09:45:19,497 INFO : org.graylog2.periodical.IndexRangesCleanupPeriodical - Skipping index range cleanup because the Elasticsearch cluster is unreachable or unhealthy
2019-12-02 09:45:43,950 INFO : org.graylog2.rest.resources.system.inputs.StaticFieldsResource - Added static field [timestamp] to input <5930de94467b8964b3304564>.
2019-12-02 10:01:34,462 ERROR: org.graylog2.periodical.IndexerClusterCheckerThread - Uncaught exception in periodical
org.graylog2.indexer.ElasticsearchException: Unable to read Elasticsearch node information
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:52) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:63) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.Cluster.catNodes(Cluster.java:119) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.Cluster.getFileDescriptorStats(Cluster.java:124) ~[graylog.jar:?]
at org.graylog2.periodical.IndexerClusterCheckerThread.doRun(IndexerClusterCheckerThread.java:56) ~[graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_71]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_71]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_71]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_71]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_71]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_71]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_71]
Caused by: io.searchbox.client.config.exception.CouldNotConnectException: Could not connect to http://10.104.196.80:59898
at io.searchbox.client.http.JestHttpClient.execute(JestHttpClient.java:80) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:47) ~[graylog.jar:?]
… 12 more
Caused by: org.apache.http.conn.HttpHostConnectException: Connect to 10.104.196.80:59898 [/10.104.196.80] failed: Connection refused
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:159) ~[graylog.jar:?]
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:359) ~[graylog.jar:?]
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:381) ~[graylog.jar:?]
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237) ~[graylog.jar:?]
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185) ~[graylog.jar:?]
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89) ~[graylog.jar:?]
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111) ~[graylog.jar:?]
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185) ~[graylog.jar:?]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83) ~[graylog.jar:?]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108) ~[graylog.jar:?]
at io.searchbox.client.http.JestHttpClient.executeRequest(JestHttpClient.java:150) ~[graylog.jar:?]
at io.searchbox.client.http.JestHttpClient.execute(JestHttpClient.java:77) ~[graylog.jar:?]
… 12 more
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_71]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_71]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_71]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_71]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_71]
at java.net.Socket.connect(Socket.java:589) ~[?:1.8.0_71]
at org.apache.http.conn.socket.PlainConnectionSocketFactory.connectSocket(PlainConnectionSocketFactory.java:75) ~[graylog.jar:?]
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142) ~[graylog.jar:?]
… 12 more
It looks like your index was created with the name “graylog_deflector” what should only be an alias to the actuall write index.
You will need to stop Graylog, rename/reindex the data into an index that actually is named correctly (graylog_3) and start Graylog again. After that rotate active write index.
That SHOULD make your problem go away. But it might be not.
