Graylog Empty - Elastic Search Problem Deflector is pointing to [graylog_729], not the newest one: [graylog_730]. Re-pointing
we use OLD Graylog
  • OS Information:
    2.4
    Now the Server is empty
    We get the message Deflector is pointing to [graylog_729], not the newest one: [graylog_730]. Re-pointing.
But the HEAP Size is ok. We make more in an other Problem in History.
How can we fix this Deflector ?
Greets
RAlf
This post may help.
EDIT: I also found this for you.
And as @jan stated in this post I quote.
Your Elasticsearch made the index read-only - the reason for that can be found in the elasticsearch log. But I guess because of missing available space …
Hello, thank you. Yes i see this topic. But where i have to write
curl -X PUT “localhost:9200/_all/_settings?pretty” -H ‘Content-Type: application/json’ -d’
“index.blocks.read_only_allow_delete”: null
Which file ? This is not what i really see in that post.
Greets
Ralf
Hello @RalfThomas
You might want to read this topic. I believe it will help you understand or perhaps enlighten you.
ok i can install this. But in which file i put
Hello
My apologies what file are you referring to?
