Correct use of remove_field in pipelines
Thanks for the help you have provided me, I appreciate too much your guidance. Currently, I moved to connect filebeat directly to graylog using Beats Input. I used to remove some fields coming in filebeat in logstash configuration as follows:
mutate {
            remove_field => [ "[prospector][type]","[host][architecture]", "[host][containerized]", "[host][id]", "[host][os][platform]", "[host][os][family]","[beat][version]", "[offset]", "[input][type]", "[meta][cloud][provider]", "[meta][cloud][machine_type]", "[meta][cloud][instance_id]", "[meta][cloud][region]", "[meta][cloud][instance_name]", "[source]"]
In graylog, I learned to use pipelines to remove any field. Then, I created a rule as follows to remove the fields:
rule "function removeFields"
    has_field("beats_type")
    remove_field("beats_type");
    remove_field("filebeat_@metadata_beat");
    remove_field("filebeat_@metadata_type");
    remove_field("filebeat_@metadata_version");
    remove_field("filebeat_@timestamp");
    remove_field("filebeat_beat_hostname");
    remove_field("filebeat_beat_name");
    remove_field("filebeat_host_architecture");
    remove_field("filebeat_host_containerized");
    remove_field("filebeat_host_id");
    remove_field("filebeat_host_name");
    remove_field("filebeat_host_os_codename");
    remove_field("filebeat_host_os_family");
    remove_field("filebeat_host_os_name");
    remove_field("filebeat_host_os_platform");
    remove_field("filebeat_host_os_version");
    remove_field("filebeat_input_type");
    remove_field("filebeat_meta_cloud_instance_id");
    remove_field("filebeat_log_file_path");
    remove_field("filebeat_meta_cloud_instance_name");
    remove_field("filebeat_meta_cloud_machine_type");
    remove_field("filebeat_meta_cloud_provider");
    remove_field("filebeat_meta_cloud_region");
    remove_field("filebeat_prospector_type");
I followed the next steps to test the change:
Stop filebeat, graylog, mongodb
Reset offset in registry
Delete graylog_0 index:
curl -XDELETE localhost:9200/graylog_0
Start mongodb, graylog, filebeat
However, I still having the fields in the search:
How to get rid of the filebeat fields?
Thanks a lot for your help
make sure your pipeline is after your extractor in the process chain, also make sure your pipeline rule is processing after the fields are created
Your rule is correct.
