marif
(Mohd Arif)
April 22, 2019, 12:23pm
1
I am able to send the logs in graylog now but all fields are showing filebeat defaults fields as per below screenshot…
I want fields like below screenshot…
I have configure it in filebeat.yml but my customize fields and getting updated in Graylog and it is showing all default filebeat fields.
filebeat.yml:
fields_under_root: true
fields.collector_node_id: ip-10-140-126-132.ap-southeast-1.compute.internal
fields.gl2_source_collector: 15709c79-2569-43bc-8679-4166fdd6dcb0
filebeat.inputs:
- type: log
enabled: true
paths:
- /data/logs/changeevent/server.log
prospectors:
fields:
Application: Glassfish
Buildingblock: changeevent
Environment: Development
Source: 10.140.126.132
input_type: log
ignore_older: 0
scan_frequency: 10s
tail_files: true
output.logstash:
hosts: ["10.140.127.133:5044"]
path:
data: /var/lib/graylog-sidecar/collectors/filebeat/data
logs: /var/lib/graylog-sidecar/collectors/filebeat/log
please check and let me know where i am missing.
tmacgbay
(Tmacgbay)
April 22, 2019, 4:36pm
2
It’s at the bottom of your Beats Input.
marif
(Mohd Arif)
April 23, 2019, 9:16am
3
Thank You!!
It is working but their are many fields are there which i do not want like below screenshot…
Now Fields is getting appended with my customize fields…
Thank you for your help.
tmacgbay
(Tmacgbay)
April 23, 2019, 1:57pm
4
marif
(Mohd Arif)
April 24, 2019, 9:50am
5
Thank You!!!
My second problem is resolved. Now fields prefix is not getting appended.
Still filebeat fields are their which i don’t want. I am trying to find out the way if i can drop these unwanted fields. I checked many article they are suggesting to create the pipeline but pipeline is come into the picture when filebeat send the data. is their any way i can use in filebeat only and do not send filebeat defaults fields to graylog?
here are the unwanted fields…
Thank You for the help!!!
jan
(Jan Doberstein)
April 29, 2019, 6:22am
7
you could create a processing pipeline that drops messages you do not want to have.
Even the rename could be possible in graylog …
